cosworth compression test ??
Old Oct 14, 2006 | 08:04 AM
cossiej's Avatar
cossiej
Default cosworth compression test ??
just about to do a compression test on my 1991 4x4 sapphire cosworth
its done 110k and idea what sort of readings i should be after ???????
many thanks jas
Old Oct 14, 2006 | 08:36 AM
Alvyn's Avatar
Alvyn
at least 140 on ALL 4 pots!
Old Oct 14, 2006 | 01:21 PM
cossiej's Avatar
cossiej
thanks lets see what we have got then ?? jas
Old Oct 15, 2006 | 08:48 AM
boost mad's Avatar
boost mad
what did you get ?
Old Oct 15, 2006 | 07:06 PM
cossiej's Avatar
cossiej
got 150 psi on cylinder 1 and 135/140 on the rest ???
Old Oct 22, 2006 | 09:06 AM
DENNIS's Avatar
DENNIS
mate, that is with in spec , when you crank the engine did you have the throttle wide open ???? would explain mismatching readings ( 8 - 10 bar std, no more than 1 bar ( 14.7 psi - 1 bar ) indifference between cylinders
if you are still worried about the indifference then give a little drop of oil in the cyl just before you do the test again, this will tell you if you have a problem with piston ring / bore wear or if its a head / gasket problem ( it may smoke a bit on restart )
1300gt
Sep 7, 2015 12:06 PM
YODI
Aug 30, 2015 01:12 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
