s1 fan belt and track arm change needed
been through the haines manual with no help.
i need to change my fan belt on the series 1 as she is squeking.
what do i have to do in order to remove and replace it??? or does it need to be garaged for such a job??
same question with the lower front left track arm replacement, not the whole thing just the end peice where the bush perishes.
thanks guys!!
The alternator belt is easy, slacken both the 13mm bolts on the adjusting arm, push the alternator home towards the block, change the belt, pull the alternator back out and use a longish screw driver to tension the belt and re-tighten the bolts
I'm not too sure on the second as to whether u mean the TCA or the tie rod?
JoeyBoyden
Jan 4, 2024 02:36 PM
155lee
Sep 14, 2015 07:37 PM
track.focus'd
Aug 12, 2015 05:53 PM
