What about spark plugs?
Oct 13, 2006 | 10:02 AM
Hello
My car is a Ford Sierra Cosworth 2WD stage 3 (24psi of boost)
For the moment, I use
Bosch f3cs spark plugs.
I will want to replace them by
denso ik27
Do you think that it is a good idea?
thanks
JY
Oct 13, 2006 | 10:52 AM
there a few lads on here that use them with good results but personly i use o71c's from ford finis code 1120834 there about a tenner and spot on for your car
Oct 13, 2006 | 01:30 PM
071's are good plugs.
Oct 19, 2006 | 08:56 AM
nobody else?
Oct 19, 2006 | 11:43 AM
i run densos on mine, no probs, although they are very cold plugs apparently?
Oct 19, 2006 | 12:26 PM
what is your denso model?
what is your car?
Oct 19, 2006 | 07:59 PM
So you seem to want to run Denso's really badly....
Most people on here with modified Cosworths will be running 071s.
There's a tonne of threads in this forum if you do a search on spark plugs.
Ford 071's Motorcraft spark plugs
Finis code 1120834 AGPS 071C
Oct 19, 2006 | 10:22 PM
mine is stage 3 and i run denso plugs, bit expensive but do the job
Oct 20, 2006 | 02:25 PM
Oct 20, 2006 | 09:06 PM
i run PP8's with no probs but going to change to NGK R1's soon
Oct 20, 2006 | 10:28 PM
Quote:
what is your car?
IK27's
Saff 4x4 running NMS Gunship+ conversion
Oct 20, 2006 | 10:33 PM
Whats the difference between IK31's and IK27's ?
well actually i am not sure what state of tune you would call it, just looked on the NMS website and its stage 3
Oct 20, 2006 | 10:39 PM
Quote:
about 4 if my calculations are correct
Oct 20, 2006 | 10:55 PM
I run 071c's good plugs but need re gaping every 2-3000mls and only last bout 5-6000mls imo
Oct 20, 2006 | 11:20 PM
i run ik27s in my car with no probs..just changed them after 7k miles...
nothing wrong with old ones but did it as part of a service...
good plugs..
Oct 21, 2006 | 07:47 AM
The IK27’s are the equivalent heat range of a 9 in the NGK range and the IK31 is a heat range of 10 in NGK.
I use the IK27’s on the street and IK31’s on the strip/track.
Oct 21, 2006 | 09:54 AM
Normally, the other interest of denso iridium is to have a very long life.
The guys who use the IK27 have which level of tuning?
Oct 27, 2006 | 09:05 AM
There is a lot of model!
Which spark plug is really the best for a "normal" use and some big boost (24psi) some times?
Iridium (Denso, NGK) one have very long life?
Pp8 too?
Nov 1, 2006 | 02:03 PM
RS & ST Parts Specialists
Nov 1, 2006 | 02:32 PM
Nov 1, 2006 | 02:53 PM
Passionford Thread Killer
071's are nice and cheap to, only they made my 4x4saff run like shit when I gave it stick.
I like the champion QC59C's, race plug so they make the car hunt a bit on idle when cold though.
Nov 6, 2006 | 10:27 PM
What gap do people set them at for 071s?
Nov 7, 2006 | 09:22 AM
For a std car- 0.85-1.0mm
For more boost(depending, less gap if running more boost)- 0.85-0.65mm.
Watch out on the 071's though because they are offset, you have to gap them at about a 45degree angle.
Nov 7, 2006 | 04:16 PM
Denso IK31's
Nov 8, 2006 | 08:29 AM
for peoples which have
DENSO , how much miles can I hope with ?
which model you have and what boost?
for 071 spark plugs, is it standard plugs or platinum?
and what aboot PP8 for 24psi?
Nov 13, 2006 | 06:11 AM
I also run 071 plugs...but they seem to misfire now and then when on full boost (I run a stage 3 with 23psi boost and I have gabbed them at 0,65 mm).... so I'm trying to figure out what to do...new gab or new plug ..????
Nov 13, 2006 | 08:02 AM
Hi Tom.. I am having the same problem Tom.. not funny!! I would sell the car
Back to the topic:
Where do you buy you DENSO´s???
Nov 13, 2006 | 09:37 AM
Quote:
Back to the topic:
Maybe I will...
Nov 14, 2006 | 05:38 AM
Are motocraft's AGPS 092C1 good for 2WD standard (next year stage 1) cosworth? My friend has bought this sparg plug by ford and they say that's for cosie
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
071 ,
bosch ,
cosworth ,
denso ,
difference ,
equivalent ,
f3cs ,
ford ,
heat ,
ik27 ,
o71c ,
plug ,
plugs ,
range ,
sierra ,
spark
