CVH cam running in
Old Oct 12, 2006 | 05:38 PM
haz87's Avatar
haz87
Default CVH cam running in
mfi xr3i-
Ok fitted a new cam, new tappets, ran it at 2500rpm for 20 mins. Now doing the 500 miles running in not going over 3000rpm but its STILL just as noisey as the old one
Any ideas?
Old Oct 12, 2006 | 07:17 PM
SafeChav's Avatar
SafeChav
Low oil pressure, wrong grade of oil, worn rockers, etc etc etc etc etc
My first stop would ge checking the oil pressure however. And also, how clean is the head? If its black and sludgey as most CVH heads are then its probably got poor oil flow
Old Oct 12, 2006 | 08:25 PM
JamboRS's Avatar
JamboRS
focus rs 1672
give it time,prob needs some miles and rpm to get the tappets filled with oil
Old Oct 12, 2006 | 10:05 PM
haz87's Avatar
haz87
Head is minty mint, oil pressure is good.
Would worn rockers cause the normal cvh tappety sound?
Old Oct 12, 2006 | 10:40 PM
MikeyXR2i's Avatar
MikeyXR2i
Defo, and it won't be to long it will wreck the new cam to. Should change everything, rockers, tappets, cam etc.
Old Oct 13, 2006 | 02:20 PM
SafeChav's Avatar
SafeChav
Worn rockers will cause the same sound if they have worn to an extent that the hydraulic lifters can't soak up the clearance, very unlikely however IMO.
As Jambo said they don't always quieten down straight away but from personal experience its usually only a matter of getting the car hot and driving it a few miles before the air is gone.
Try taking the rocker cover off, and using the rule of 9, play with each rocker and see if there is any play. If its a problem related to excessive wear it will be evident when doing this.......
JK12
33
Apr 26, 2021 12:09 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
xrmalin
Sep 13, 2015 06:52 PM
rog
Sep 4, 2015 07:24 AM
