Efi TB's
What do people do with the Idle air control valve? Normally it's connected to the fiesta crossover. I suppose it could be routed to atmo via a mini filter.
Hang on hang on, how can you block the ISCV off.........
You can either put a breather filter on it and leave it like that, OR run a pipe and connect it back into the intake system somewhere.
liamT74
Sep 23, 2015 10:24 PM
