diff help
Old Oct 11, 2006 | 09:28 PM
steveo135's Avatar
steveo135
Default diff help
is the diff in a rwd granada the same as a sierra rwd diff only i have bought one for mine not sure if they are the same.
thanks
Old Oct 11, 2006 | 11:35 PM
Alvyn's Avatar
Alvyn
I believe the 2.9 model uses a 7.5" lsd diff but you have to change the flanges where the drive shafts bolt on! I dont know if their the same ratio as in the saffie though!
Old Oct 12, 2006 | 09:12 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i got a 7.5" from a 2.9 scorpio auto to replace the broken 7.5" in my 2wd cossie.
the output shafts that i removed from my 2wd diff were not compatible with the scorpio diff, but i was able to use the ones that came with it. they were basically the same as the 2wd ones, but without the outer lip that the driveshaft sits in.
Old Oct 12, 2006 | 12:09 PM
steveo135's Avatar
steveo135
Default diff
cheers guys thats a great help.
steve
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Fezman1
Sep 7, 2015 09:34 PM
cbminis
Sep 7, 2015 09:42 AM
