Saff Cos Dash Prob
When I indicate all my warning lights come on dim, im thinking bad earth somewhere. Has recently had a spedo cable (not by me) so somehting could be disturbed?
Are they easy to take out?
If thats the prob
If thats the prob
easy enough to do
remove the clock surround (4 screws - 2 top, and 2 hidden behind pry-off covers at bottom of surround), unplugging 2 rotary switches for dash light intensity and wiper speed
you may need to remove the steering column upper and lower surrounds depending on if you've got a fixed or adjustable steering column or not
undo 4 screws to remove clocks
pull the clocks forwards enough for you to reach around the back to unclip the speedo cable, then unplug the main multiplug and ABS wiring plug
you will find you've got more space if you remove the steering wheel and indicator and wiper stalks first if you can be bothered
