Strange boost gauge readings???
Old Oct 10, 2006 | 09:07 PM
cosrep's Avatar
cosrep
Default Strange boost gauge readings???
Just fitted an electronic boost gauge to the cosworth, rather than a tube running all the way to the gauge it has a boost sensor that mounts under the bonnet. I spliced into a vacuum tube running from the inlet manifold as describded in the instructions. A tee piece is installed and a small lenght of tube runs to the sensor. The sensor is then connected to the gauge by wires.
When at idle the gauge reads about -21 psi (vacuum) when revved it climbs towards the 0 mark on the gauge but will not surpass this point, no matter how hard I rev the engine it will not register any +psi (boost).
I thought the gauge its self might be fautly so I connected a vacuum gauge in place of the boost sensor and found the same readings, when I connected a small compressor to the boost sensor it measured up to the full 30psi
Anyone any thoughts? Am I missing somthing here? :-?
Old Oct 11, 2006 | 04:56 AM
captiva's Avatar
captiva
Default boost probs
Boost pressure will not register until you are driving it. The correct way to test it is to drive in 4th gear at 3500 rpm and then apply the brake (momentarily) while keeping your foot on the gas
Old Oct 11, 2006 | 10:06 PM
Sideways_Sierra's Avatar
Sideways_Sierra
I thought the same when I installed my boost gauge the other month.... but gave her a pasting and she's running a mere 9 psi !
Old Oct 13, 2006 | 03:32 PM
mark taylor's Avatar
mark taylor
try driving the car not just sitting in it reving as i am sure you wont get boost till its under load.cheers mark
Old Oct 15, 2006 | 08:44 AM
boost mad's Avatar
boost mad
as has been said above, the car wont make positive boost unless under load..... so that means driving it
Old Oct 15, 2006 | 09:31 PM
cosrep's Avatar
cosrep
Thanks for the info guys, just had me worried there for a while, incidently how would you test boost pressure without driving the car?
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
