new clutch slipping?
Hi Huys I fitted a new clutch a few weeks ago, but I think its slipping in boost. Im only running 12psi so its obviously not too much power thats causing it. IS there any adjusting or something that I can do to help prevent this? Thanks in advance fro suggestions!
very much doubt yu can help this mate,, mines running at 12 psi and it slips like fooook on boost,, sounds like the car is wheel spinning,, i would advise u to go for a paddle clutch but you wont get a AP paddle for less than Ł250 dude...
im buying one next week
most likely rear cranckshaft oil seal, oil most likely contaminating the clutch hence the slipping. I always have my flywheel skimmed and have a new oil seal fitted when i do a clutch.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
