Best BoV
Old Oct 9, 2006 | 09:55 PM
Bakster's Avatar
Bakster
Default Best BoV
Witch blow off valve will be better for efi managment??
Old Oct 10, 2006 | 06:03 AM
JesseT's Avatar
JesseT
Don't know what efi you mean, but management that are based on a map-sensor instead of an air-flow-meter, are completely insensitive to the type of valve used.
Old Oct 10, 2006 | 07:04 AM
Bakster's Avatar
Bakster
So it can be anyone witch I buy
Old Oct 10, 2006 | 07:37 AM
Mr Shannon's Avatar
Mr Shannon
"No" Valve is best
Old Oct 10, 2006 | 10:16 AM
davsmith64's Avatar
davsmith64
if u running EFI why use a dump valve?? when you get a loud better sounding chatter noise??
IMO i think that dump valves are gay even tho i had one on my old S2..
i run EFI on my ERST and would never ever use a dump valve again,, just go for the chatter dude.
Old Oct 10, 2006 | 04:22 PM
Badman38's Avatar
Badman38
unless you've got a roller bearing turbo then you have no choice but to run one and i bloody hate then.
Old Oct 10, 2006 | 05:04 PM
Oranoco's Avatar
Oranoco
Unless you're running aGT series turbo don't bother with a dumpvalve. They do next to bugger all apart from make you sound like a bus.
Old Oct 10, 2006 | 05:09 PM
scottbrown's Avatar
scottbrown
lol
I like the sound of a bus
beats the sound of turkeys
Old Oct 10, 2006 | 05:22 PM
RS-adam's Avatar
RS-adam
chatter all the way mate
Old Oct 10, 2006 | 08:51 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Check out my latest mod! Scania pneumatique brake conversion gives a decent "woosh"...
Just kidding. :P :P :P
Well I've got a dump valve fitted, too. First drive was awesome, big grin on my face.
But now I'm getting a bit tired of it.
Old Oct 11, 2006 | 06:59 AM
Bakster's Avatar
Bakster
I don't understand.... when I start make my engine I have 1,1 bar boost... and I have bov.... so now when I will have aboyut 1,6 boost I don;t have to put bov??
Old Oct 11, 2006 | 11:38 AM
Oranoco's Avatar
Oranoco
You don't need it mate. I run my S2 at 25psi (1.72bar) and it's never had a dumpvalve on it. My Fiesta RST is running at 15psi (1.03bar) and also runs no dumpvalve. Up to date I've never had any issues with either despite both being driven very hard.
Old Oct 11, 2006 | 04:12 PM
Badman38's Avatar
Badman38
t series turbos dont produce enough back pressure to cause damage, so unless you run a t4 a dump valve or bov is not needed.
Old Oct 13, 2006 | 12:18 PM
Little_Hoss's Avatar
Little_Hoss
why is one needed on a roller bearing turbo?
Old Oct 13, 2006 | 12:37 PM
Bakster's Avatar
Bakster
now I have T4
Old Oct 13, 2006 | 03:33 PM
Badman38's Avatar
Badman38
roller bearing turbo shaft is very thin so the air getting blocked by the shut butterfly can in some cases snap the compressor wheel off the shaft
Locke040390
Fiesta RS1800/RS Turbo
13
Aug 8, 2012 03:54 PM
ShiftyOldScoob
11
Sep 12, 2009 07:06 PM
