CAN ANY ONE HELP??
Old Oct 7, 2006 | 10:17 PM
STROBEY's Avatar
STROBEY
Default CAN ANY ONE HELP??
I AM CURRENTLY FITTING A PRO ALLOY FRONT MOUNTED INTERCOOLE AND TWIN SLIM LINE 'SPAL' FANS WHAT IS THE BEST WAY TO MOUNT THE FANS???
I HAVE HAD SUGGESTIONS OF BOLTING THEM THROUGH THE RAD IN BETWEEN THE FINS, BUT I'M NOT SURE THE RAD IS STRONG ENOUGH
WOULD IT BE BETTER TO FABRICATE A BRACKET FOR THE FANS MOUNTED TO THE SLAM PANEL AND BOTTOM MEMBER, OR ALTERNATIVELY CAN I BUY A KIT TO MOUNT THEM?
CHEERS FOR ANY ADVICE
Old Oct 8, 2006 | 03:14 AM
gambit's Avatar
gambit
Default mounting fans
pro alloy do the fan kit but you have to buy two new fans as they are slightly bigger and it comes with an alloy mounting bracket. Check it out on there web page
Old Oct 8, 2006 | 07:17 AM
HORNETS7's Avatar
HORNETS7
cheapest way would be to fabricate some brackets m8!
don't bolt through the rad or u'll be wanting a new rad in a week or 2
