warning settings
Old Oct 5, 2006 | 07:25 PM
S3an's Avatar
S3an
Default warning settings
want to set the warning lights on my new spa gauges and was wondering what temps i should set the warnings for on the water and oil temps. its stage 3 running approx 340/350bhp. any help appreciated.
Old Oct 5, 2006 | 08:53 PM
heeman10's Avatar
heeman10
I'd be going for around 95C water and 260F oil.
Old Oct 5, 2006 | 09:51 PM
G1EN's Avatar
G1EN
have you got pics of it fitted.. the spa dashes are fooking sweet.
Old Oct 6, 2006 | 09:59 AM
S3an's Avatar
S3an
260*F thats approx 125*C surely that cant be right
went out in the car last night and the oil temp was reading generally between 60*C and after a little thrash the highest it got to was between 75*C and 78*C
Old Oct 6, 2006 | 12:03 PM
heeman10's Avatar
heeman10
Mine sits at 210F with very easy driving, rises to 240F with hard driving and if driven on a hot day at prolonged high revs it will edge towards 250F.
What gauges are you using to monitor your temps? Do you have an aftermarket air-oil cooler? If so, is it thermostatically controlled?
Old Oct 6, 2006 | 12:53 PM
S3an's Avatar
S3an
not 100 % on this but ive just been told that motorway, pottering driving should see about 60/65*C and on a thrash rising till approx 80*C and on a track day etc should only rise to about 95*C so if your cars oil temp is showing 125*C+ this is way to high
Old Oct 6, 2006 | 02:54 PM
heeman10's Avatar
heeman10
Yeah I'm waiting to hear back from an informed source too...it's possible that although I'm using good quality gauges, their sensors may not be as good. I wouldn't expect false readings from Auto Meter equipment though
Old Oct 6, 2006 | 03:25 PM
heeman10's Avatar
heeman10
Word has come back - 120C max, specifically stated for the oil I use (Motual 8100 5W30), which equates to 248F Mine doesn't exceed 240F on a normal hard drive, and generally sits at 210-220F (99-104C).
Old Oct 7, 2006 | 10:37 AM
S3an's Avatar
S3an
its not a dash as such just gauges where the radio was
Old Oct 7, 2006 | 12:13 PM
heeman10's Avatar
heeman10
I like the look of those
Old Oct 7, 2006 | 09:37 PM
markk's Avatar
markk
the oil needs to get up to over 80 deg c when using the car, if it doesnt it will emulsify, the max should be up to 120deg c , also the water temps should also be at 90-95 deg on an escort, up to a max of 115ish tho i have seen 125 with no worries
steve.rst
Mar 15, 2016 08:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
3doorcozmess
Sep 7, 2015 01:32 PM
