ABS problem with 3dr
Old Oct 4, 2006 | 06:58 PM
B11GNS's Avatar
B11GNS
Default ABS problem with 3dr
My abs light is coming on when it shouldn't be. It comes on as normal when the car is switched on from cold then goes out quite quickly. Problem is its coming back on after about 5-10 mins of driving and stays on. Anyone any idea what the problem might be?
Old Oct 6, 2006 | 01:45 PM
B11GNS's Avatar
B11GNS
Come on, someone throw me a bone here!
Old Oct 6, 2006 | 03:58 PM
IANS2RST's Avatar
IANS2RST
have you got differebt sized tyres on the front & rear axles?
if so the tyre size can be enough for the abs light to come on when u reach a certain spedd. other than that clean all the sensors & the teeth on the hubs also checking for any that are broken
Old Oct 6, 2006 | 04:59 PM
B11GNS's Avatar
B11GNS
Wheels are different but they have been for a while and the problem has only just started. I will try cleaning the sensors and checking them though, ta
Old Oct 7, 2006 | 01:40 PM
Alvyn's Avatar
Alvyn
check for damage and clean the sensors and the fuse for abs(under near the pedals also disconnect the abs ecu for a few mins then reconnect the latter sorted my problem!
Old Oct 7, 2006 | 05:07 PM
B11GNS's Avatar
B11GNS
Where is the abs ecu located?
Old Oct 10, 2006 | 08:47 PM
Alvyn's Avatar
Alvyn
down near the pedals on a 3dr(looks like the engine ecu plug but yellow)!
Old Oct 11, 2006 | 08:00 AM
B11GNS's Avatar
B11GNS
Cheers, i'll have a nose
Sierrasideways
Oct 8, 2015 06:37 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
155lee
Sep 23, 2015 01:27 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
