solenoid control valve
Hi guys the control valve which sits on the top of the intercooler on a 4x4 saff, mine is clicking when you touch the plug also sometimes when driving, i have re fitted the plug with no differance so guess must be in the valve itself was wondering if i can use an uprated one or an alternative ?
it will be the SEM valve (often mistakenly reffered to as the amal valve
). they have a habit of coming apart a bit inside and making a dodgy contact.
there are alternatives, but none simple and direct. your best bet is to get a new replacement, otherwise you will need a bleed valve (then the ecu has no control over boost), a boost controller, air to air injectors or whatever.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
