coil overs or not ?????????
Old Oct 3, 2006 | 08:57 PM
DENNIS's Avatar
DENNIS
Default coil overs or not ?????????
I AM TRYING TO DECIDE IF I SHOULD RUN COILOVERS OR NOT TO SOLVE MY WHEEL CLEARANCE PROBLEMS ON THE FRONT ,
I USE IT FOR ROAD USE SO I DONT WANT IT TO BE TOO HARD
BEEN TALKING TO GAZ AND THEY HAVE OFFERED TO MAKE EM UP TO SUIT ( THE ONLY COMPANY TO OFFER ME THIS !!)
WHAT ARE YOU RUNNING ? HOW ARE THEY ???
HELP
CHEERS
Old Oct 3, 2006 | 09:42 PM
THE RADMAN's Avatar
THE RADMAN
tried gaz, far too hard for road use in my opinion,they just clonked and rattled down the road,took em straight off and back to my konis
Old Oct 3, 2006 | 09:48 PM
DENNIS's Avatar
DENNIS
CHEERS DO YOU KNOW WHAT SPRING RATE THEY WAS ???
I HAVE KONI ON NOW HANDELS FANTASTICLY, ONLY OUTHER OPTION IS MOD THE LEG AND FIT 15 - 20 MM SPACERS
Old Oct 3, 2006 | 10:09 PM
THE RADMAN's Avatar
THE RADMAN
cant remember mate im afraid
Old Oct 3, 2006 | 10:18 PM
L3 COS's Avatar
L3 COS
i have gaz coilovers on mine... i personally think it rides spot on,havnt had a problem with mine,no cluncks or rattles im well pleased with the way it drives..
but every1 to there own
Old Oct 3, 2006 | 10:31 PM
NEIL A's Avatar
NEIL A
i have gaz coilovers specced by cossymad off of here and havent had any problems with them, have heard that some kits come with alot harder springs.
Old Oct 4, 2006 | 06:27 AM
THE RADMAN's Avatar
THE RADMAN
you will prob also have to modify the rear turrets for clearance
Old Oct 4, 2006 | 10:34 PM
lowman's Avatar
lowman
i have bilstein motorsport ones.and i am happy with the ride.pretty much go cart ISH ride ,but its firm and the way i like it
Old Oct 4, 2006 | 11:07 PM
Kelv's Avatar
Kelv
Almost there!
i have Gaz on my car, was running 325 fronts and 225 rears which is as Gaz spec them.
car is fine on the track or european roads but is slightly to harsh for UK road use (IMO)
Changed my rear spring rates to 190 and it took alot of the harshness out of the ride, but still handles really well.
will be selling mine as soon as i can get them off the car if you wanted those - only chnaging mine as been to Nurburg with Mike Rainbird and im now going to upgrade mine to Leda's which are almost 3 times the price of the Gaz
Old Oct 5, 2006 | 07:07 AM
MONSTER's Avatar
MONSTER
Hi Kelv, what factors persuaded you to go to leada's. I've also been thinking about the leda's off mike but at £1200 I want to be sure they're right for me.
Old Oct 5, 2006 | 07:15 AM
kjc300's Avatar
kjc300
Dennis, what exact clearance probs are you having??
As the spring platform on konis needs 'adjusting' with 18" wheels!!!
Have you had this done already??
Old Oct 5, 2006 | 07:21 AM
kjc300's Avatar
kjc300
only pic I have - the bottom spring cup just needs adjusting to suit.
Old Oct 5, 2006 | 08:27 AM
redrsmk5's Avatar
redrsmk5
I have gaz on mine they are fine i have them set perfect front and rear, spent ages setting them up with 2 clicks at a time front and rear so it was spot on.
Old Oct 5, 2006 | 05:04 PM
DENNIS's Avatar
DENNIS
I RUN TOYO R888 TYRES 235/40/17 AND THEY JUST RUB AT 130MPH+
I HAVE NOT DONE THE MOD TO THE LEG YET AS I AM STILL DECIDING WHAT WAY TO GO.
I MAY GIVE IT A GO FIRST AS I DONT REALY WANT TO GO COIL OVERS
THERE *KIN BIG BRAKES ON THERE !!!!
Old Oct 5, 2006 | 05:59 PM
july1's Avatar
july1
I expect to buy Leda by the end of the year
Old Oct 5, 2006 | 06:52 PM
M.A.D.RST's Avatar
M.A.D.RST
Get some pics up of your car
Old Oct 5, 2006 | 07:00 PM
DENNIS's Avatar
DENNIS
I WILL DO, NEED TO SORT A GOOD CAMERA OUT FIRST
Old Oct 14, 2006 | 03:36 PM
DENNIS's Avatar
DENNIS
i got some pro spacers on there now, dont look to bad and solves my clearance problem with out going to coil overs or knocking the leg about...
got longer studs in the kit but think i will fit even longer ones for safe sake..
before
and after
and the kit
Old Oct 14, 2006 | 04:16 PM
Kelv's Avatar
Kelv
Almost there!
Dennis, what ofset are your wheels then?
and what thickness are the spacers youve opted for?
Old Oct 15, 2006 | 09:27 AM
Rolls's Avatar
Rolls
Get on the phone to Mike Rainbird, and ask his advise - i've got one of his set-ups, and it is perfectly suited to the road IMO
Old Oct 15, 2006 | 09:06 PM
rsdene's Avatar
rsdene
going to say i have got 19's and gaz coilovers and i think the ride is just right. i use mine loads on the road
Old Oct 16, 2006 | 09:53 PM
DENNIS's Avatar
DENNIS
i cant remember the ofset , and the powder coat is so thick i cant read it now . the spacers are 15mm thick
marky_g
Sep 12, 2015 04:26 PM
gcfcos
Sep 11, 2015 06:03 PM
jonfoc
Sep 11, 2015 04:46 PM
dms04
Sep 11, 2015 01:57 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
