help me please on what i should expect to pay info pls ???
Hi all im looking to buy a fue parts and i would like to know the going rate on what i should expect to pay for the following items.
how much for the following.
L8 ecu with stage3 chip.
2wd cossie ecu loom
3 bar map sensor
is £500 for the lot a bit expencive ????
also could you tell me how to tell what level an ecu is. ie what number should i expect to find on what vairent of ecu
do fords still supply / stock new ecu`s or will be a case of second hand stuff?????
thanks gys all help appreciated.
2wd cossie ecu loom
3 bar map sensor
ecu with chip £200 - 250 used
loom £200 used
MAP sensor £80 brand new
so £500 is about right
personally, i would not buy a used loom. i would get a new one of dingy (le-claw) or ryan
don't know their prices, but quality is spot on. old looms could be unreliable
do a search, there are plenty of posts with pictures of L8 ecu's and the correct numbers
loom £200 used
don't know their prices, but quality is spot on. old looms could be unreliabledo a search, there are plenty of posts with pictures of L8 ecu's and the correct numbers
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
