Welding advice 3 Door Sierra floor
Old Oct 2, 2006 | 05:48 PM
Chairman's Avatar
Chairman
Default Welding advice 3 Door Sierra floor
My brother is a profession welder, does it for a living, but not on cars,
My 3 Door Sierra needs the floor fixing around where the front seats are bolted to the floor, this is the back of the seat on the outer side, nearest the seat belt mounts..
Is it best to repair it inside the car, or on the underside? the underside looks very awkward to do, and ive got the entire shell stripped out anyway so its 1 or the other, no biggie which..
Old Oct 2, 2006 | 07:56 PM
foreigneRS's Avatar
foreigneRS
Testing the future
from an mot and structural point of view, it doesn't matter as long as it's a continuous seam.
inside is easiest, but then you will leave a gap between panels on the underside that will be prone to holding water and rusting again. but you can paint it or underseal or whatever (depending on how much you love your car and how long you want it to last).
if you do it from underneath, then you will have the gap inside, which can be just as bad if you have a carpet that can trap water under it.
you could also do both sides.
FlashRS
Sep 14, 2015 12:36 PM
borboyous
Aug 22, 2015 11:17 AM
Vincereese
Aug 15, 2015 06:24 PM
mpilk
Aug 12, 2015 09:40 PM
Vincereese
Aug 11, 2015 08:39 AM
