turbo diesel wastegate actuator question
ok i know its not a rs sorry
but a 2.5 iveco turbo daily, turbos quite noisy like a gushing sound, not sure if its a sucking gush or a blow type
anyway noticed the wastegate arm seems to be locked solid so im presuming siezed, hopefull ill be able to free it off but would that create that sort of noise?
that would create that noise, due to the fact that if its seized open, then the turbo is blowing all the pressure out through the wastegate...
also, your unit will be working double time to create the usual boost.....
also, as said....check all pipes for leaks, splits, hose come off,.....
Matt Baxter
Sep 16, 2015 08:30 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
