40 DCNF Vacuum help
Old Sep 28, 2006 | 09:17 PM
mentalasanything's Avatar
mentalasanything
Default 40 DCNF Vacuum help
I have a pair of Webber 40 DCNF carbs on my XR2. The problem I'm having is that I've plugged a TIM vacuum gauge in to a port on each carb and I'm not getting any readings. Am I being a dumbass or are the ports circled in red below not the vacuum ports???
I dont understand!
Lee
Old Sep 29, 2006 | 03:24 PM
mentalasanything
Right, the carb on the left (One with brake servo outlet) has a pipe sticking out of the front of it, is this a vacuum, as i've seen pics on the web of these carbs with pipes off there!
I'll try it!
Old Sep 29, 2006 | 06:13 PM
costina's Avatar
costina
Live long and prosper!!
Don't think the small ones are vacs but the one on the inlet is some pinto manifolds come with a twin take off one big one small ideal for wot u need
Old Sep 29, 2006 | 08:20 PM
killerscum01's Avatar
killerscum01
Hi
If your trying to use them for tuning there is an easier way to balance them which i devised when i had a lotus sunbeam. pm me if you're interested.
Cheers: Bart
Old Sep 30, 2006 | 09:26 AM
mentalasanything
Cheers Lads, the one on the manifold is connected to the brake servo, so I dont particularly want to T this one.
I'm not trying to tune them, They're balanced already, I'm trying to find out why there was no reading!
I've been told that all 4 vac's need to be connected together and then to the dizzy, otherwise whatever is connected directly to one port will only pulse for a quarter of a cycle, which makes sense.
I will ask tho killerscum01 mate if you could describe how to tune them!
Lee
Mark RS
Oct 12, 2015 06:01 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
hopper350
Sep 4, 2015 12:53 AM
