PISSED OFF!!!!!!!!!
Old Sep 27, 2006 | 06:12 PM
davsmith64's Avatar
davsmith64
Default PISSED OFF!!!!!!!!!
okay, my car began to tick over on 3 cylinders for some reason,, ive changed plugs/leads,, theres a deffo spark on the cylinder that is down....
but when i rev it, it freely revs up on 4..
put on the compression tester just now to check it,,
tested the cylinders and cylinders 1,2,3are showing 140psi,, where as cylinder 4 is down at 80 psi!!!!!! now the car is testing my paitience!
it is a freshly rebuilt engine 1300miles ago,, everything new, low comp forged pistons ect!!!
hopefully it may be the head gasket but aint using oil or water!!!
or a dodgy valve, lifter or rocker..
i have a spare std head but now thinking of stage 3 head,.
my luck!!!
also changed lifters and rockers, hoping i wouldnt need the head off...lol
and still the same!!
Old Sep 27, 2006 | 06:20 PM
RST Ski's Avatar
RST Ski
could be a burnt out valve
Old Sep 27, 2006 | 07:45 PM
NEWTON's Avatar
NEWTON
or a fucked tappet,i had a brand new kent cvh 37 cam kit and one of the tappets let go,resulting in cylinder 3 was down to 65psi but prob fixed now ill post a pic of it soon
Old Sep 27, 2006 | 08:06 PM
davsmith64's Avatar
davsmith64
changed the tappets and followers and still the same!!!!
i hope its either the head gasket or a burnt out or slightly bent valve..
Old Sep 27, 2006 | 08:09 PM
NEWTON's Avatar
NEWTON
the valve shouldnet be bent,unless the belt has jumped a few teeth
Old Sep 27, 2006 | 08:26 PM
gup's Avatar
gup
is the lobe on the cam alright and not worn out i have had that on a customers car
Old Sep 28, 2006 | 10:58 AM
scotty86d's Avatar
scotty86d
whats the difference between a tappet and follower?
Old Sep 28, 2006 | 11:15 AM
slimwynn's Avatar
slimwynn
it may not be a burnt out valve it just mite need lapping in a bit.
Old Sep 28, 2006 | 11:17 AM
SafeChav's Avatar
SafeChav
Do a leak test, that will soon show where the pressure is being lost.
Old Sep 29, 2006 | 06:40 PM
HORNETS7's Avatar
HORNETS7
i reckon uve got a bolt stuck in the inlet thats jamming open the inlet valve on one of your cylinders!
Old Oct 1, 2006 | 01:46 PM
SafeChav's Avatar
SafeChav
where does a bolt suddenly appear from inside inlet manifold.......
Old Oct 1, 2006 | 08:42 PM
HORNETS7's Avatar
HORNETS7
from when the numpty lost a bolt when building the head he never found it and its been found in the inlet manifold thats what jammed his inlet valve open and fooked up the valve seat!
Old Oct 1, 2006 | 08:58 PM
SafeChav's Avatar
SafeChav
Ah right so is that actually whats happened then?
Old Oct 2, 2006 | 07:49 AM
HORNETS7's Avatar
HORNETS7
yup went to his the other day and the bolts been in there for 1300 miles and its just caused a problem!!!!
the bolt has no threads left on it and is highly polished lol!
Old Oct 2, 2006 | 12:24 PM
SafeChav's Avatar
SafeChav
dojj
Sep 29, 2015 10:32 PM
gcfcos
88
Sep 15, 2015 03:48 PM
Guinnless
Aug 21, 2015 06:36 PM
EssexBoyRacer
12
Jun 21, 2004 02:40 PM
Feb 9, 2004 08:19 PM
