right so i know these supressors were fitted to ofab cars to stop interferance from the ht's effecting the map sensor signal. my cars ofac so is it possible that this is having an adverse effect?
yeah tried unplugging it and nothing. thinking about it cant really see it having an adverse effect but the cars driving me nuts with the not running right
no air leaks and not convinced on map sensor yet. ordered one off ebay but it was faulty
idles really poorly intermittantly then holds back now and again. idle speed control valve is ok for poor idle and starting to think ecu is a at fault for holding back and jerking
look at your pipes for cracks or splits mine ticked over like a bag of nails and smoked and wouldnt boost over 5 psi because a small diameter pipe had poped off on the boost guage
