ECU question
Old Sep 26, 2006 | 08:54 PM
Maxxeh's Avatar
Maxxeh
Default ECU question
I dont understand the colour codes on the ecu.
ive seen a series 1, red, blue, red, What does that mean. whats the difference between them all?
Old Sep 26, 2006 | 10:38 PM
DazC's Avatar
DazC
S1 85 spec is Blue red Blue.
S2 86 spec is Blue red white.
S2 88 spec is Blue red black.
S2 90 spec is Hearts hash diamonds.
Nothing more than a way to distinguish between different type of ECU's. They were also used on Sierras as electronic ignition modules with carb control but they were different colours again.
Old Sep 26, 2006 | 11:23 PM
Maxxeh's Avatar
Maxxeh
I got a series 2, wud it matter which ecu i get. I need to get one with unlimited boost.
Old Sep 27, 2006 | 05:04 PM
Moonie's Avatar
Moonie
All standard ECUs have a boost limit, think its somewhere around 10psi
Old Sep 27, 2006 | 07:22 PM
addiction's Avatar
addiction
why dont you just get yours chipped?
Old Sep 27, 2006 | 07:29 PM
Maxxeh's Avatar
Maxxeh
it is mate. i got a ahmed bayjoo chip. But their pants! i need a unlimted boost chip.
Old Sep 27, 2006 | 08:15 PM
Zetecfiesta's Avatar
Zetecfiesta
well ive got an 88 spec car but with a 90 spec ecu in it! probably getting a series 1 ecu though and doing away with knock sensor!
Old Sep 27, 2006 | 08:31 PM
Maxxeh's Avatar
Maxxeh
why is it better not having a knock sensor?
Old Sep 27, 2006 | 08:41 PM
addiction's Avatar
addiction
you can still get your ecu chipped again using a different chip!
Old Sep 27, 2006 | 09:42 PM
Zetecfiesta
if your head on the turbo is getting quite rattly the ecu thinks its the car knocking so it cuts the boost back!
Maxxeh: why do you need an unlimited boost chip? its better to have something mapped to your car's spec!
Old Sep 27, 2006 | 10:45 PM
addiction's Avatar
addiction
a knock sensor retards the ignition to prevent detonation
Old Sep 27, 2006 | 11:42 PM
SafeChav's Avatar
SafeChav
In the event of knock happening...........but cam rattle cam also cause ignition retard.
Old Sep 28, 2006 | 09:01 AM
Maxxeh's Avatar
Maxxeh
thats wats its doing at the moment. Its retarding the inginiton. Apparently im loosing like 20+ bhp.
Old Sep 28, 2006 | 09:18 AM
SafeChav's Avatar
SafeChav
You've got 2 options.
You can either use a Series 1 ECU which doesn't have the input for the knock sensor, or you could plug in a knock sensor and tuck it up out of the way.
Its important to have the sensor plugged in if you are using a ECU that has an input for a knock sensor otherwise it will still also retard the timing.
Old Sep 28, 2006 | 05:30 PM
Maxxeh's Avatar
Maxxeh
ill probs go for a s1 ecu.
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
