Diagnose this engine prob?Update ZVH help please!?
Old Sep 26, 2006 | 08:23 PM
turbo terry's Avatar
turbo terry
Default Diagnose this engine prob?Update ZVH help please!?
As above FRST with an 1800 ZVH and de-comp plate.
Blue smoke when driven above 2.5k, no smoke when idling and up to say 4k at a stand still? No oil on spark plug either.
Drives ok so not valves etc?
Compression test read as follows
1 - 11bar
2 - 11bar
3 - 10bar
4 - 5bar
Got to be a piston prob or HG??
Old Sep 26, 2006 | 08:26 PM
Rs1's Avatar
Rs1
Time to take the head off and have a look
Old Sep 26, 2006 | 08:28 PM
melzieann's Avatar
melzieann
Time for Henry the Eight Off with its head
Old Sep 26, 2006 | 08:31 PM
turbo terry
lol be off with the bitches head it be!
De-comp plate cause problems generally?
Old Sep 26, 2006 | 08:34 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Could be shattered ring lands on No4 mate, seen way to much of this latley Hopefully not though Whip the head off and see. If no signs of failure time to remove a piston
Is it breating heavy when you remove the oil cap?
Bri.
Old Sep 26, 2006 | 08:40 PM
turbo terry
Havn't tried removing the cap with it running TBH, should it struggle??
Why out of interest is it a regular occurance on num 4?
Cheers for the help!
Old Sep 26, 2006 | 08:56 PM
*Bri.4.b.Cos*
Its not regular mate, i have just seen my mates engine die 4 times of this you could hear it DETTING a mile away turned out to be the fuel pump wiring faulty.
Most likley to be the head gasket gone though, but if not remove the piston and check.
Bri.
Old Sep 26, 2006 | 09:28 PM
xr2i-carl's Avatar
xr2i-carl
yeah also just to point out, when a compression test was done x amount of weeks ago the first three were all within couple psi of each other. why would have this one got worse since,
thanks
carl
Old Sep 26, 2006 | 09:36 PM
turbo terry
do you know if it was num 4 last time? could be faulty injector etc perhaps?
also bit dodgy you have lost compression within a few weeks?
have to take the bitch apart 2moro.
Gutted about your mates engine bud, this one will be number 4 rebuild wont it this time carlos?
Old Sep 26, 2006 | 09:41 PM
Stu.H's Avatar
Stu.H
its probably the cooking oil
Old Oct 4, 2006 | 10:22 PM
turbo terry
Head is off now, no visible damage to the tops of the pistons will take the low cylinder one out at the weekend.
No signs of HG fooked.
None of the oil galleries have been plugged off as they should be, which ones should be the front four?
Also runs a de-comp plate and where there is i believe a water jacket hole there is only a small hole in the gasket and plate which only covers half the hole, if that makes any sense, doesnt to me I'll stick pics up 2moro.
Which HG should we be using on an 1800 zetec?
Can i reuse the decomp plate?
Old Oct 5, 2006 | 12:53 PM
xr2i-carl's Avatar
xr2i-carl
why would the compression be sooo low if the pistons are okay???
could the block be cracked????
sooo confused!!!!!
caRl
Old Oct 5, 2006 | 04:24 PM
turbo terry
rings probably, or summit else.
Old Oct 5, 2006 | 05:19 PM
IANS2RST's Avatar
IANS2RST
if its still running the t2 turbo then this will be the cause of the smoke as the zetec oil pump runs at higher pressure than the cvh 1 & due to the design of the oil return t2s are prone to failing as the oil pressure is to much for the sealing ring. even if itsa t3 this could still be the cause.
as for compression, did you do a wet & dry compression test as this would tell u if the problem was the head /gasket or the rings.
have the valves pressure tested to make sure they are sealing & get rid of the decomp plate as they are wank!
Old Oct 5, 2006 | 05:42 PM
turbo terry
Cheers ian
It is still running the t2 and has fooked a few of em, could be through this, no way of leaving the t2 on there?
No way of lowering the cr without machining pistons etc is there?
I only did a dry comp test, mate did a wet one said the compression went up considerably but said he put a fair amount of oil in?
What head gasket would you recommend on a 1800?
What about the plugging of oil galleries? Doesn't seem to have any?!
Thanks again mate Very helpful!
Old Oct 6, 2006 | 11:35 AM
xr2i-carl's Avatar
xr2i-carl
Hi Ian,
thanks for the detailed reply, i hav not had the net for few days sohavent checked this post. I have only fooked one t2 before, i originally thought it was a turo problem because was down on power and chattered very quietly!
in we scrap the decomp plate will the compression not rise considerably?
the head has een skimmed before twice so think thats why the plate was fitted in there?!!!
if we fit some more standard machined zetec ones what boost will these take safely?
thanks
carl
Rstar_man
143
Jul 20, 2020 11:16 PM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
blackbeautyzetec
Sep 11, 2015 03:10 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
fatboy billy
Aug 3, 2015 08:34 AM
