Map Sensor Supressor for OFAB EFi
How many people are actually using these. I read that some people don't use them and have had no problems. I have one so will be wiring it in anyway but was just curios.
Dave
Dave
You should wire one in really mainly to stop HT interference and so on, chances are it will be fine without but there is a chance it could get intereference and as a result the ecu will be looking at the wrong part of its MAP and it could all end in tears.....
Originally Posted by SafeChav
I believe that is correct, i have a 1990 FRST Ford Diagram here and its also not on that, but i wonder why Ford started fitting them
REALLY
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
