S1 won't start. Help please !
Old Sep 24, 2006 | 04:39 PM
Series1Dry's Avatar
Series1Dry
Default S1 won't start. Help please !
Fooking typical. As soon as i talk about possibly parting with the old girl, she decides she aint gonna start for the 1st time since i bought her 2 years ago. Put her to bed last nite and everything was ok. Tried to start her this morning and she won't. She turns over fine but there is no spark to the plugs. Fuel getting through fine. Had the dizzy off and without taking it apart to check the connections inside, it seems ok. Could it then be the coil ? Opinions please. cheeRS, Dry
Old Sep 24, 2006 | 05:22 PM
SafeChav's Avatar
SafeChav
Is the pump running when you are turning the engine over? Or does it only prime?
Old Sep 24, 2006 | 05:28 PM
Series1Dry's Avatar
Series1Dry
It running all the time. Well i assume it is cos when we were seeing how far the fuel was getting, my mate had the nut on the fuel filter slightly undone and it continuously sprayed petrol over him while it was trying to start. Does that help ?
Old Sep 24, 2006 | 05:32 PM
SafeChav's Avatar
SafeChav
Hmmmmmmmm, from what you say it would probably be a wise assumption to say the pump is running, however - i want you to give me a definate answer.........
Go and get the keys
Old Sep 24, 2006 | 07:42 PM
andyt's Avatar
andyt
Dry i have a workin coil you can try as i put a GRP A one on my s1, can drop it off tom if needed
Old Sep 25, 2006 | 07:43 PM
Series1Dry's Avatar
Series1Dry
Thanx Andy but borrowed a working one off my mates S1 and it's still the same. Did manage to get it running for about 15 mins and then it stalled. Tried my mates coil and it's still the same. Will start now but stalls immediately. She was popping and farting and stalling when i was limping back home in her. Any ideas folks? cheeRS
Old Sep 25, 2006 | 08:11 PM
andyt's Avatar
andyt
Mine done this mate it was one of the plugs i coud not belive it aswell when i changed them
Old Sep 25, 2006 | 08:31 PM
Series1Dry's Avatar
Series1Dry
Will soon see as i was about to change the plugs anyway. Doubt it though as i had no spark on any of them yesterday. This could have been a poor connection on the lead from the dizzy to the coil. I made sure there was a good connection before and i got it running for 15 mins but now it starts but won't tick over. Now it could be a dodgy plug. Fooking cars
Old Sep 25, 2006 | 08:52 PM
andyt's Avatar
andyt
same symptoms as mine mate , i had to drive mine home farting and burping away on just above tick over (every time i put my foot down it got worse) changed the plugs and away she went again
Old Sep 26, 2006 | 08:38 AM
SafeChav's Avatar
SafeChav
As said in the PM gut feeling is the dizzy packing up. HOWEVER have you checked your dizzy cap and rotor arm lately
Old Sep 26, 2006 | 09:01 AM
Series1Dry's Avatar
Series1Dry
Yeah checked them and seems fine. The centre bit on the dizzy cap that touches the rotor arm is spring loaded is'nt it. How much tension should there be when you try and push it in? Mine pushes in and does come back out but there is'nt much force behind it. Could it be there is'nt a good connection to the rotor arm ?
Old Sep 26, 2006 | 10:22 AM
SafeChav's Avatar
SafeChav
Its only a soft spring as long as its springing back thats fine.
So the contacts aren't pitted or burn't or anything then? My Orion broke down just short of a year ago and it was the brush stuck in the cap, but after i free'd it off it kept playing up anyway cos the contacts were all so badly pitted and stuff.
Bought a new cap and arm and its been mint ever since, AND it had always had a really annoying intermittent mis-fire which also turned out to be that.
Old Sep 26, 2006 | 10:38 AM
Series1Dry's Avatar
Series1Dry
Contacts are fine mate. Shiny as a new pin. Also cleaner the rotor arm and centre contact connection but still the same. Could it be that the contacts are just worn down ?
Old Sep 26, 2006 | 10:42 AM
SafeChav's Avatar
SafeChav
No if they are as clean as you say then it should be fine. I still have my money on the sensor in the distributor personally..........
Old Sep 26, 2006 | 10:50 AM
Series1Dry's Avatar
Series1Dry
Is this the black plastic connection on the distributor with the wires running inside the distributor ? How can i check if it's this ?
Old Sep 26, 2006 | 10:54 AM
SafeChav's Avatar
SafeChav
Indeed it is. Well....this is why i ask you about the fuel pump. The fuel pump relay takes a signal directly from it, so if the pump doesnt run its a dead give away
You could try a simple bulb wired from it to the battery but i dont think it will show a fault very well being as the car still tries to run.
Does your mate have a spare dizzy by any chance?
Old Sep 26, 2006 | 05:02 PM
Series1Dry's Avatar
Series1Dry
Right. Just found that the fuel pump primes ok then when you turn it over it runs for a second then stops. This would either point to the relay or a fooked pump i would presume ? Where is the relay ? Is it one of the yellow ones in the fuse box ?
Old Sep 26, 2006 | 06:13 PM
SafeChav's Avatar
SafeChav
Check to see if you have spark when it does this aswell.............
Old Sep 26, 2006 | 06:22 PM
Series1Dry's Avatar
Series1Dry
Check to see if i have spark when it's turning over with and without the pump running do you mean? Also, are s1 and s2 pumps the same ?
Old Sep 26, 2006 | 06:29 PM
SafeChav's Avatar
SafeChav
when it does the thing where the pump only runs for a second check for spark.
Do that before u do anything else.
Old Sep 30, 2006 | 04:08 PM
Series1Dry's Avatar
Series1Dry
Distributor fooked. Problem solved. cheeRS
Old Sep 30, 2006 | 06:20 PM
andyt's Avatar
andyt
Old Oct 1, 2006 | 01:48 PM
SafeChav's Avatar
SafeChav
Told ya so
You can be happy again now
Old Oct 1, 2006 | 07:16 PM
Series1Dry's Avatar
Series1Dry
Funny how once you solved a problem on your car, it turns from a worthless piece of shit you wish you had never bought, to a beautiful RS that you would'nt part with for anything
cheeRS for the input guys. . . well, safechav and Andy anyway
Mile30
69
May 13, 2017 08:44 PM
A.t.p
Oct 23, 2015 07:54 PM
dojj
Sep 29, 2015 10:32 PM
jay030787
Sep 18, 2015 04:38 PM
fuzzy
Sep 4, 2015 10:11 PM
