revv limit 2.0 ZVH
Old Sep 24, 2006 | 03:38 PM
Gregor's Avatar
Gregor
Default revv limit 2.0 ZVH
I've had my 2 liter ZVH rst on the rollers last week, deliverd nice power but the revvs stopt @ 6000.
it's a little annoying because my turbo really starts spinning @ 4500 rpm
Goes like hell to 5500 and then slowly to 6000.
Thinking of putting on a smaller turbo to get full boost @ around 3500 but it should rev much higher!!!
what could be the problem... wrong cam timing??
Bought an adjustable poulie yesterday and wil fit that soon but when that's sorted should i get more revvs or could there be something else wrong...
Thanx a lot
Old Sep 24, 2006 | 07:44 PM
Badman38's Avatar
Badman38
Default Re: revv limit 2.0 ZVH
Thanx a lot
that is a shite power band but you have got a 8v head which just abouts supplies enough air for a 1.6, trying to feed a 2.0.
what ever turbo you are running its not speced very well full boost @ 4500rpm
Old Sep 24, 2006 | 08:23 PM
Gregor's Avatar
Gregor
well.. i've seen zvh's making revves over 7000 rpm.. i've got a stage 3 head with a kent 35 cam... that should be enough for at least enough flow to reach the standard limiter shouldn't it?
I know the powerband is shit..... boost should be there at least at 3500-6500....
Old Sep 25, 2006 | 06:55 AM
Badman38's Avatar
Badman38
zvh making power @ 7000rpm look at what ever graph you where looking at again.My 2.0zvh shows peak power @ 5929 but i can still rev it to 7000 cant see the point if its not making power. who mapped your car because at one point my was showing 368bhp at 6592rpm on 26psi but when he up the boost and adjusted the timing and fuelling i lost revs.
Old Sep 25, 2006 | 08:25 AM
Gregor's Avatar
Gregor
hey, i didn't say it made power at that revv range, just said the engine could revv that high.. mine just stops @ 6000 rpm...peak power is @ 5550.
it has't properly been set up because it's getting to hot.
But just asked if the problem with my revvs could be in wrong timing..
Will sort that and then will get it set up propperly.
Don't think you know the guy who's setting up my car... local tuner here in Holland
But i'm not gonna get verry high revs then....so i'll have to change the turbo to get boost a lot earlier,,,
any idae what turbo to use??
Thnx
Old Sep 25, 2006 | 11:23 AM
Rick's Avatar
Rick
What turbo have you got? ZVH's do not rev very well sadly.
Old Sep 25, 2006 | 12:14 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
My little CVH is still making good power after 6500! It is on full boost (2-Bar)by around 4000rpm too.
As others have said, the ZVH' s do fail in the high rpm area.
Old Sep 25, 2006 | 03:19 PM
Badman38's Avatar
Badman38
Thnx
my bad did'nt notice you came from holland for your application 4x4 cosworth hybrid turbo will come on boost nice and early and still make good power, or better still try a roller bearing turbo and cheap but do the job.
Old Sep 25, 2006 | 09:09 PM
Gregor's Avatar
Gregor
I've got a stage 3 turbo from universal turbo's.. cosworth turbine wheel, 0.48 exhaust housing and 360 degrees bearing.. had it on my 1.6 before this but as zvh wón't rev verry well i have to put on something else
Old Sep 25, 2006 | 09:14 PM
rapidcossie's Avatar
rapidcossie
do a search for posts by Andy_R he posted a ZVH power graph up not long ago
Old Sep 25, 2006 | 09:15 PM
Gregor's Avatar
Gregor
Thnx
Hmzz... 4x4 hybrid turbo.. what specs am i looking at then?
What turbine and exhaust housing (what parts are standard 4x4 and what's hybrid? )??
and when will it kick in and what boost can i run it?
Thanx again
Old Sep 25, 2006 | 09:16 PM
rapidcossie
https://passionford.com/forum/viewto...892&highlight=
try that..
the car runs a t38 and about 25 psi
peak is at 6k
Old Sep 25, 2006 | 10:15 PM
Rick's Avatar
Rick
u'd need to goto a 63 housing. Being on boost at 4k is not good - my turbo is bigger than yours and mine's a 16...
Old Sep 25, 2006 | 11:10 PM
stuart collins's Avatar
stuart collins
custom speced gt30 roller bearin on my 1600 on boost at 2500rpm full boost(2bar) at 3800rpm still makin power over 7000rpm
same turbo on a zvh on boost at 1500-2000 rpm
they both run tubular manifolds aswell
Old Sep 25, 2006 | 11:15 PM
Gregor's Avatar
Gregor
63 housing... is that on a cos turbo or do i need to get a hybrid??
Old Sep 25, 2006 | 11:16 PM
Gregor's Avatar
Gregor
verry verry nice , but i think that;s a little over my budget.....
Old Sep 25, 2006 | 11:37 PM
Andy_R's Avatar
Andy_R
Over 7000peak power can be achieved but will require different inlet and exhaust manifolds and things then do start to get pricey......
Fitting a smaller turbo will give you better spool up but peak power will remain around the 6k figure.....just the nature of the ZVH unfortunatley.
Old Sep 25, 2006 | 11:49 PM
Gregor's Avatar
Gregor
I can live with peak power 5500-6000 rpm
Just wanna know what kind off turbo to fit then......
Goal is tot get full boost at aroud 3000-3500 rpm @ 20 psi
Old Sep 26, 2006 | 12:12 AM
Andy_R's Avatar
Andy_R
Cant see why your not getting boost earlier tbh, with the turbo your using you should see full boost way earlier than 4500rpm....something's not right!
Personaly id focus my attention on making what you do have work more efficiently, rather than spending money on another turbo.
Old Sep 26, 2006 | 12:19 AM
Gregor's Avatar
Gregor
Hmzzzz, buit what could be restricting the turbo from making boost earlier???
Got a rolling road graph of my rst and it shows boost is full @ 4500rpm....
What should be the rpm for full boost with my engine and tubrbo???[/img]
Old Sep 26, 2006 | 12:26 AM
Andy_R's Avatar
Andy_R
Should certainly be seeing full boost around 3000-3500rpm.
Old Sep 26, 2006 | 08:11 AM
Gregor's Avatar
Gregor
Hmzzz.. what could be the problem then ??
Old Sep 26, 2006 | 11:24 AM
Christian and Beccy
#1 in Spelling Club
If it's the graph that you are relying on to decide when your turbo is making full-boost, then it really is important that the rolling-road operator used an accurate method for measuring RPM.
Stuart, what torque does yours make at 7000rpm?
Old Sep 26, 2006 | 01:41 PM
stuart collins
on the 1 graph i got its makin around 240-250lbft @7000 that wasnt the finished map so dont no
Old Sep 26, 2006 | 09:44 PM
Gregor's Avatar
Gregor
It's not just on the graph but also when i'm driving it... it takes ages before i get some acceleration and @ arround 4500 it goesssssss....
http://www.mijnalbum.nl/Foto=DHTSDGY8
Old Sep 26, 2006 | 11:59 PM
Christian and Beccy
#1 in Spelling Club
I would like to see a clearer image of that graph.....
Old Sep 27, 2006 | 07:59 AM
Gregor's Avatar
Gregor
Can't seem to upload it any bigger.. check your email..
Old Sep 27, 2006 | 08:05 AM
Christian and Beccy
#1 in Spelling Club
I have seen the graph, thanks.
I would suggest that you check the adjustment of the actuator and that the wastegate is functioning correctlly (not jammed).
That would be my starting point.
What actuator is it?
Old Sep 27, 2006 | 08:09 AM
Gregor's Avatar
Gregor
Ok thanx, will do that.
Got an old actuator here so will try that on just to see if it's spinning op bettter.
My current actuator is supposeed to be an -65 or something.. swapped it for a -31 never should have done that.....
gonna buy a -31 again.
thnx for now..
Old Sep 27, 2006 | 08:15 AM
Christian and Beccy
#1 in Spelling Club
Yes, fit a -31 and set it with the right amount of pre-load. If it's holding the wastegate open, it will certainly give the effect of additional lag.
Keep up posted with what happens.
Also, take a quick look over the hoses and Intercooler etc for leaks.
Old Sep 27, 2006 | 11:38 AM
Gregor's Avatar
Gregor
Put on an old actuator... does't boost higher then 0.5 bar.. have tot tighten it but no time for today.... turbo spins up earlier @ around 3500 it seems....
couldn't try it good though...... got out of fuel on the highway ... and got towed away bij my dad's corsa
Old Sep 27, 2006 | 12:12 PM
Christian and Beccy
#1 in Spelling Club
But are you setting the pre-load correctly? How are you doing it?
Old Sep 27, 2006 | 08:31 PM
Gregor's Avatar
Gregor
I get the rod from the actuator of the wastegate en turn it in or out ... then pull out the rod and slide it over the pin on the wastegate..
Old Sep 30, 2006 | 06:00 PM
ShandzS1's Avatar
ShandzS1
i would put half a hole of pre-tension on the wastegate
Old Sep 30, 2006 | 06:13 PM
Gregor's Avatar
Gregor
That's about what i got now....
building pressure now from 2500 rpm and ful boost at arroud 3500
Old Oct 1, 2006 | 10:11 AM
Christian and Beccy
#1 in Spelling Club
So would you say the problem is cured? (and my diagnosis was correct??!!)
Old Oct 1, 2006 | 12:20 PM
Gregor's Avatar
Gregor
Yes.. you could say that...
I had the amalvalve on with the -65 actuator with no pre-tension.
Now i've got a standard actuator and a bleedvalve in staed of the amal-valve...
Boulding up boost much earlier and full boost is earlier too.
now i've got the problem of boost getting late after i've changed gears.. takes halve a second before it's there but i'll open another topich on that couse we're wondering off the subject what this was originaly about..
Thanx a lot all
mk3ste
Oct 17, 2021 10:09 AM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
The Enigma
Sep 29, 2015 10:31 AM
SMILER258
Sep 28, 2015 09:04 AM
