cam kit for xr2i
Old Sep 24, 2006 | 02:39 PM
focisport's Avatar
focisport
Default cam kit for xr2i
if i bought a stage 2 head for my xr2i 8v would have to buy a full cam kit or could i get away with just a cam?
Old Sep 24, 2006 | 03:15 PM
MarkN's Avatar
MarkN
You should never fit old lifters to a new cam, and you also need to use cam lube when you're fitting a new cam too.
You really need the kit as otherwise you'll have to buy all the bits seperately.
Old Sep 24, 2006 | 04:00 PM
SafeChav's Avatar
SafeChav
Never on a CVH will you get away with fitting a new cam with old lifters because they wear so bad.
A kit isn't a lot more anyway.
Old Sep 24, 2006 | 04:05 PM
focisport's Avatar
focisport
thanks alot which kit is the best to go for?
Old Sep 24, 2006 | 04:20 PM
MarkN's Avatar
MarkN
Its down to personal preference really. I was thinking of getting a Kent CVH32 which is supposed to have a power band between 1500 and 6500 RPM.
I've been hearing bad things about Kent cams wearing out so I've stuck with a new standard one for the moment and will probably get a Piper next year.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
