ESCORT RS2000 MK5 92 STARTING PROBLEM
Old Sep 24, 2006 | 12:53 PM
danrs2k's Avatar
danrs2k
Default ESCORT RS2000 MK5 92 STARTING PROBLEM
Does anybody know where i can get a wiring diagram from for my rs2000 16v 92 k reg.
No power going down to the solenoide from the ignition switch.
Old Sep 24, 2006 | 03:17 PM
MarkN's Avatar
MarkN
I've seen this a couple of times before on Mk5 Escorts. It normally turns out to be a burnt out track in the fusebox.
It could be the ignition switch, and it could also be corrosion in the single bullet connector in the black/red wire that runs near to the battery.
Fusebox is most likely though.
You'll have trouble finding a wiring diagram for an RS2000 as the only ones I know of are in the Ford TIS system. The starting system is the same as the zetec versions I believe so you can probably use a Haynes manual.
Old Sep 25, 2006 | 08:22 AM
danrs2k's Avatar
danrs2k
thanks for your help i will check this out tonight and post up how i got on.
Old Nov 3, 2006 | 10:50 AM
danrs2k's Avatar
danrs2k
right i have put a new fuse box on and redone my wiring n i cracked it the car was startin fine but after a week its gone back to its usual self by not starting to get it started now i have to connect a piece of wire from the starter n then touch the other end to my battery then that turns the starter
when turnin the ignition key to start normaly the dash lights dont even go dim so thats telling me its NOT sending poer to the starter.
what can i try next???
Old Nov 11, 2006 | 05:11 PM
16vzetec's Avatar
16vzetec
take a wire and attatch it directly to the back of the key wire which i believe is black and blue.
bypass the fuse box.
you cant go wrong!
Vincereese
Jun 1, 2023 09:14 AM
RockinRein
Aug 19, 2015 07:08 PM
Vincereese
Aug 16, 2015 06:38 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
