secs monitor coolant temp
could anyone tell me what temp there secs monitor shows? as mine has had a wobbly last time i took it out going over 95 then saying its out of analog field? could it be the wires to the coolant temp sensor
cheers well i will have another go at the weekend stripped back the sheaf... on the wires and they are not burnt only at the plug end, if not i will change sensor as i have spare one cheers thankyou.
ok chaps thanks
will have a see today what its at, wires looked ok put them in bit of heat proof casing jus in case they gettin to hot
Mark RS
Oct 12, 2015 06:01 AM
mk1focus
Ford Fiesta
Sep 24, 2015 06:19 PM
