cant boost above 2-3psi!! help!! Options
Old Sep 24, 2006 | 07:58 AM
davsmith64's Avatar
davsmith64
Default cant boost above 2-3psi!! help!! Options
ok here we go again!!!!!!!!
ok i bought a boost gauge to see what i was boosting,,
it was boosting at 5psi,,
turned up the actuator and still boosting at 5psi!!!
i am not running a amal valve just a closed loop from the actuator to the turbo!!
so i tryed it without no pipes on the actuator to see if it would actually boost above 5psi,, and yeah it did!!
so i thought my actuator was fooked!!! i have recently bought a brand new forge actuator with 9-15psi spring and tryed that and its still the same!!!
its running efi management with beige injectors,,
standard turbo...
NO AIR LEAKS!!!!!!
any1 any ideas??
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Sp3no
Sep 27, 2015 07:23 PM
