cant boost above 2-3psi!! help!! Options
Old Sep 23, 2006 | 05:20 PM
davsmith64's Avatar
davsmith64
Default cant boost above 2-3psi!! help!! Options
ok here we go again!!!!!!!!
ok i bought a boost gauge to see what i was boosting,,
it was boosting at 5psi,,
turned up the actuator and still boosting at 5psi!!!
i am not running a amal valve just a closed loop from the actuator to the turbo!!
so i tryed it without no pipes on the actuator to see if it would actually boost above 5psi,, and yeah it did!!
so i thought my actuator was fooked!!! i have recently bought a brand new forge actuator with 9-15psi spring and tryed that and its still the same!!!
its running efi management with beige injectors,,
standard turbo...
NO AIR LEAKS!!!!!!
any1 any ideas??
Old Sep 23, 2006 | 07:25 PM
xrchris's Avatar
xrchris
does it hold the few psi of boost it getting? or does it start to jerk like its hitting boost cut?
Old Sep 23, 2006 | 07:52 PM
davsmith64's Avatar
davsmith64
no it holds it, its not jerking about or overboosting..
Old Sep 23, 2006 | 08:26 PM
HORNETS7's Avatar
HORNETS7
i reckon scrap it m8 sounds a shed to me !
Old Sep 23, 2006 | 08:46 PM
davsmith64's Avatar
davsmith64
shut up u numpty, u have a few sheds at yours..lol
Old Sep 23, 2006 | 09:01 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Weird...
Maybe there's a mechanical fault of the waste gate flap or a crack in the turbine housing.
Did it really boost properly without the hoses? Or just "better"?
Old Sep 24, 2006 | 07:51 AM
davsmith64's Avatar
davsmith64
yeah it boosted properly.,, but i only took it to 10-12psi as it may have fooked uo the turbo..
Old Sep 24, 2006 | 09:58 AM
user 7082039239
Well I'm not sure whether it is possible to get decent boost with a closed loop. You would have have to shorten the actuator rod a lot if your running without amal/bleed valve which in the end isn't good for the waste gate flap/housing.
I'd just throw in a bleed valve and try. If it's still not boosting good enough I'd check the turbine housing of the turbocharger for cracks.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Sp3no
Sep 27, 2015 07:23 PM
