i/c
Old Sep 23, 2006 | 03:44 PM
s22gav's Avatar
s22gav
Nosey RS parker
Default i/c
bollocks to the cost, couple of quid here or there aint gonna matter just want the best i/c out to of them!!!
think its gotta be pace by the looks of it!!
Old Sep 23, 2006 | 04:03 PM
dave_y's Avatar
dave_y
GRS Motorsport
Old Sep 23, 2006 | 04:26 PM
addiction's Avatar
addiction
GRS
Old Sep 23, 2006 | 06:42 PM
gus's Avatar
gus
if you can afford to wait then GRS
or pro alloy have a new one very soon i think
Old Sep 23, 2006 | 10:25 PM
LEE-RS's Avatar
LEE-RS
Custom
the pace single pass
Old Sep 24, 2006 | 12:52 AM
craig rs's Avatar
craig rs
grs all the way
Old Sep 24, 2006 | 11:54 AM
Oranoco's Avatar
Oranoco
PACE front mount big mother. Simply faultless
Old Sep 24, 2006 | 02:13 PM
turboben's Avatar
turboben
go on ebay there has been a few grs on there recently
Old Sep 24, 2006 | 03:04 PM
stevenebm's Avatar
stevenebm
post whore
grs!!!!!!!!!!!!!!!!
Old Sep 24, 2006 | 07:10 PM
Šhatter Box's Avatar
Šhatter Box
pace if u got the money imo
grs are about as good as a brick wall for air flow and boost drop
I have got the new pro alloy on mine u get no trouble with it what so ever as with the top one u do
Old Sep 24, 2006 | 09:50 PM
addiction's Avatar
addiction
never had any boost drop with my GRS, my act never goes above 34 and my water temp never goes above half
Old Sep 24, 2006 | 10:04 PM
stuart collins's Avatar
stuart collins
grs run 1 on mine no probs with temp at all
seen temp up to 78+on 2 pro alloy , great
Old Sep 24, 2006 | 10:09 PM
dave_y's Avatar
dave_y
my car was running 15psi and after i added GRS cooler it was hitting 20psi.
the new pro alloy one does look good though how much is it going to cost?
Old Sep 25, 2006 | 11:05 AM
turboben's Avatar
turboben
are people running 2 or 1 fans on there grs
Old Sep 25, 2006 | 11:07 AM
dave_y's Avatar
dave_y
2 fans
Old Sep 25, 2006 | 03:56 PM
addiction's Avatar
addiction
2 on mine
Old Sep 25, 2006 | 04:51 PM
rstel1's Avatar
rstel1
ive got the new autospecialists airtek one fairly new on the block runs good on mine ant the will be 260-270 including fans speak to alen or roy at autospecialistson 01375 850062 and tell them terry sent you they will look after you
Old Sep 25, 2006 | 10:44 PM
Šhatter Box
i dont know ask pro alloy i dont work for them
i got 90c on my old pro alloy
but how much harder does your engine have to work to make your boost as the poor air flow
Old Sep 25, 2006 | 10:50 PM
stuart collins
no idea but its happy with boost at 2.24bar so cant be that bad
Old Sep 25, 2006 | 11:11 PM
Andy_R's Avatar
Andy_R
Just to clarify! Im assuming that the temps being quoted do not relate to Air Charge Temps and were not measured whilst moving where boost is being produced?
If im right in my assumptions what relevance if any do the quoted temps have to do with the intercoolers?
Old Sep 26, 2006 | 08:47 AM
cabrst's Avatar
cabrst
don't forget RADTEC I/C.....
Old Sep 26, 2006 | 03:53 PM
JamboRS's Avatar
JamboRS
focus rs 1672
well the ic debate goes on
firstly ive got a grs so my opinion isnt buyist,grs on mine is good,but i have been told that i need a single pass one for reasons that alex said,it struggles to keep boost held high up in the rev range and was told to go for the pace front mount as its acts are top notch and still single pass with a huge coolin area
id go for the pace one if money is no object if not grs is the best of the rest
or you could always get some cossie ones welded up and a reverse charge pipe made up,better than all quoted above
Old Sep 26, 2006 | 03:59 PM
addiction's Avatar
addiction
yes they do relate to air charge temps and when moving,well mine do anyway!!
Old Sep 26, 2006 | 06:04 PM
Andy_R's Avatar
Andy_R
What!!!!!! Thats mental 90° & 78° sound more like what id expect to be seing from water temps not ACT's.
Old Sep 26, 2006 | 06:16 PM
Rab's Avatar
Rab
Fucking superstar........
So hang on a moment? You're charge temp is 90 degrees??????
For gods sake it leaves the turbo at about 110-130 degrees.... Even just the boost pipes on there own would cool it to 90 degrees. You lot must run methanol to control the DET.
Old Sep 26, 2006 | 06:17 PM
addiction's Avatar
addiction
aint it just
stevieel
Apr 21, 2006 11:53 AM
bud-weis
57
Nov 4, 2005 04:37 PM
cossied
Feb 16, 2005 10:14 AM
Kelv
Dec 21, 2004 04:39 PM
Kelv
Dec 21, 2004 02:59 PM
