Another strange one, Alternator???
Old Sep 22, 2006 | 05:22 AM
Avinitlarge's Avatar
Avinitlarge
Default Another strange one, Alternator???
Ive come across another strange problem on my car, Ive started a new job and I have to go for a 20 min drive down the motorway every day, When I get to work or get back home the idle is really rough and any lights that are on go bright and dim, The head unit turns on and off too. It only does it when I drive on the motorway though.
Old Sep 22, 2006 | 12:00 PM
SafeChav's Avatar
SafeChav
Is the battery being charged though? Has it gone flat yet?
Old Sep 22, 2006 | 02:54 PM
Avinitlarge
Battery doesnt go flat. Drove home just now, Had to drive steady cos of the weather, It was ok when I get home, Ive also left it idling for about an hour and it was ok, It only seems to happen when I give it some thrash
Old Sep 22, 2006 | 09:05 PM
Wardy257's Avatar
Wardy257
Do you have a multimeter so you can do a few tests?
Old Sep 22, 2006 | 10:00 PM
Avinitlarge
I do indeed
Old Sep 22, 2006 | 10:03 PM
Wardy257's Avatar
Wardy257
Check this out:
http://forum.fordsierraclub.co.uk/viewtopic.php?t=18853
Old Sep 23, 2006 | 10:21 AM
CosKev3's Avatar
CosKev3
Have you got the heat shield on the back of the altenator????
Sounds like the altenator is getting too hot from the heat soak from the manifold/turbo
Fitted a re-con alt on my saph last year,lasted 2 days,had a good blast and it melted the regulater off the back of the altenator
This was before I realised there is supposed to be a heat sheild on the rear of alt
Made one out of an old piece of turbo heat shield now
Old Sep 23, 2006 | 11:49 AM
Avinitlarge
It could be that, The alternator is on the back of the engine and the turbo on the front
Old Sep 23, 2006 | 06:00 PM
MarkN's Avatar
MarkN
It could be that the diode pack has failed and is letting current flow through the alternator the wrong way.
Just a thought...
Old Sep 23, 2006 | 07:28 PM
CosKev3's Avatar
CosKev3
Sorry m8,thought I was reading posts in the Cosworth section
jonfoc
16
Sep 11, 2018 05:35 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
jay030787
Sep 18, 2015 04:38 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
