engine only running on 3 cilinders
Old Sep 21, 2006 | 03:24 PM
escort cab's Avatar
escort cab
Default engine only running on 3 cilinders
my 1800cc zetec is only running on 3 cilinders i have checked that spark plugs and the leads and they are both sparking
anyone have any idea - i really miss driving my car
Old Sep 21, 2006 | 09:43 PM
Wardy257's Avatar
Wardy257
An igniton fault is unlikely to cause a ZETEC to run on 3 cylinders, its 4, 2 or none.
Use an LED tester or NOID light to check for injector switching. What oil are you using, if it is not the proper 5/30 valve problems are common.
Old Sep 21, 2006 | 10:02 PM
escort cab's Avatar
escort cab
i thought that 15/30 was the one to use. its definet;ly only the oone cilinder as i checked all the others and they seeem fine, ithought it may be a bent valvebut i am more yjan likely to be wrong
Old Sep 21, 2006 | 10:05 PM
Alvyn's Avatar
Alvyn
check compression on the cylinder thats missing and go from there!
Old Sep 21, 2006 | 10:15 PM
Wardy257's Avatar
Wardy257
If a valve problem it will just be sticking, if you have been using 15/30 then that is now a prime suspect.
Old Sep 22, 2006 | 02:12 AM
Zetecfiesta's Avatar
Zetecfiesta
check it aint the spark plugs just had my car fixed as that was missing and it had a cracked spark plug and broken maf!
Old Sep 22, 2006 | 08:48 AM
escort cab's Avatar
escort cab
I did check the plugs but i will check again,
Compression test will be later on tonight - haynes manual out again
If it is a sticking valve i do i solve it? - is it head off and new valve or???
Old Sep 22, 2006 | 11:30 AM
SafeChav's Avatar
SafeChav
15w30 in a zetec. Oh dear
should be 5w30 and nothing else
Old Sep 22, 2006 | 09:13 PM
Rsailor's Avatar
Rsailor
What about the coil? had that problem with my rs2000 and a coil had gone.
Old Sep 23, 2006 | 06:12 PM
MarkN's Avatar
MarkN
A coil would affect two cylinders not just one. Could be the injector wiring is faulty but the oil needs changing first.
You should be able to diagnose a valve sticking that badly by doing a compression test.
big_Rad
Sep 15, 2017 09:36 AM
Red_bull
Aug 25, 2015 06:27 PM
Zoggon
Aug 10, 2015 10:39 AM
knight19770
Aug 4, 2015 12:36 PM
lockie
Jul 31, 2015 10:03 PM
