Cone Filters/Air Boxes, I dont know.
Old Aug 23, 2004 | 03:52 PM
Jobbo's Avatar
Jobbo
Default Cone Filters/Air Boxes, I dont know.
I have just Bought a group A K&N filter for my 93 large turbo Escos, but have now heard varying reports on how good they are ie they suck in too much hot air and crap!!
Should I stick to the standard air box or change?
Old Aug 23, 2004 | 04:13 PM
wimwerf's Avatar
wimwerf
no....they suck warm air in when you are standing still with the car. but when you drive the car...there will be enough cold air under the hood.
Old Aug 23, 2004 | 04:23 PM
Jobbo's Avatar
Jobbo
Cheers M8tey, really want to fit it, it will look
Should there be a nipple on the trumpet to re locate the hose that used to go into the air box?
Old Aug 23, 2004 | 04:31 PM
rapidcossie's Avatar
rapidcossie
AIRBOX!
Old Aug 23, 2004 | 05:42 PM
wimwerf's Avatar
wimwerf
which one you have. the one with the aluminium trumpet. maybe you must buy an oil breather system.
Old Aug 23, 2004 | 06:33 PM
DaveEscos's Avatar
DaveEscos
jobbo
pm
Old Aug 23, 2004 | 07:03 PM
Jobbo's Avatar
Jobbo
Wimwerf, yes matey it is the Mumma Large group A version with the alloy trumpet,
Car is running Stage 2, 803 greens, 1.5bar, not had the car long and always wanted one, It's expensive, tiring, worrying and takes up loads of my time.
I FOOKIN LOVE IT!!!!! rison:
Old Aug 23, 2004 | 09:54 PM
wimwerf's Avatar
wimwerf
okay...its the same stage i have. you could buy a small filter for the hose. or you could buy an oil seperator kit.
Old Aug 24, 2004 | 09:51 AM
Jobbo's Avatar
Jobbo
Cool Thanks for the help Wimwerf, much appreciated
Old Aug 24, 2004 | 11:06 AM
wimwerf's Avatar
wimwerf
Old Aug 24, 2004 | 03:48 PM
Dave Henshall's Avatar
Dave Henshall
OEM airbox with cold air feed from the brake cooking dect from the edge of the radiator inlet with a fresh PAPER OEM element every time u drop the oil/filter.
Old Sep 4, 2004 | 08:48 PM
mk5cos's Avatar
mk5cos
i am tempted to get a pannel filter but surley by letting more air through, the filter proccess must be worse, so resulting in wear on the turbos blades and cylinder bores?
i have had them in my non turbos but they are not forced induction like the turbos.
any opinions?
1 garage said just dont use a filter!!!! needless to say i did not take up his recomendation. he really thought it would do no harm!!
Old Sep 24, 2004 | 05:12 PM
bigpower's Avatar
bigpower
i rekon the airbox with pannel filter is the better option........lost power with a k&N induction kit before!
Old Sep 24, 2004 | 08:58 PM
abdr500's Avatar
abdr500
k and n and pipercross have put in a lot of money to make thoues fillters thers tested on wrc rally cars and they drive them hard and the dust condition ther put under i think that ther good for turbos and noramily asp engine i run 2bar on my cossy with a group a cone filter and nothing has gone bang the air box bering in mind can flow the same amount off air then a cone filter its only a space saving option for most big powere car that have all tanks every were and need to move things to gaine space
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
A.t.p
Sep 29, 2015 05:04 PM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
