Oil Pressure Readings?
Old Sep 20, 2006 | 03:48 PM
Mr Shannon's Avatar
Mr Shannon
Default Oil Pressure Readings?
Fitted my oil pressure gauge today and I'd like to know what it should be reading at cold idle, warm idle and whilst under load.
Ta muchly in advance chaps
Old Sep 23, 2006 | 11:13 AM
Badman38's Avatar
Badman38
Default Re: Oil Pressure Readings?
cvh cold idle 60psi warm idle 15-20psi under load 40psi. zvh cold idle 75psi warm idle 25psi under load 50psi.
Old Sep 23, 2006 | 11:59 AM
BRAMMER's Avatar
BRAMMER
My old fiesta used to be 70psi cold - 15-25psi idle - under load 40-45psi so around these sort of figures is right
Old Sep 23, 2006 | 02:02 PM
Mr Shannon's Avatar
Mr Shannon
Everything seems fine going of those figures except my warm idle which is around 5psi
Old Sep 23, 2006 | 03:21 PM
BRAMMER's Avatar
BRAMMER
very strange, so its basically got no pressure whilst idling, that can't be good.
Old Sep 23, 2006 | 05:48 PM
Mr Shannon's Avatar
Mr Shannon
Just been out in it and it was at 10psi when it was idling warm but sometimes the revs drop slightly and it goes right down to around 5psi.
To note though, the iscv is unplugged due to it idling at 2k when its connected. Also its a low comp bottom end if that makes any difference
Old Sep 23, 2006 | 06:02 PM
BRAMMER's Avatar
BRAMMER
Could be lower because of the compression but i can't be 100%.
Old Sep 23, 2006 | 06:10 PM
Chrissy_bwoy's Avatar
Chrissy_bwoy
is it mechanical or an electrical sender on the gauge?
Old Sep 23, 2006 | 06:34 PM
Mr Shannon's Avatar
Mr Shannon
Mechanical I think
Old Sep 23, 2006 | 06:47 PM
Chrissy_bwoy
does it have a tube direct from the oil pressure switch? or just a bit of wire?
if its mechanical, where are you taking the feed from? oil pressure switch at the back of the block? also the tube could be kinked causing low pressure
Old Sep 23, 2006 | 07:20 PM
Mr Shannon's Avatar
Mr Shannon
No its got a bit of wire going from the sender to the gauge, its on a T piece with the oil pressure switch in the block
Old Sep 23, 2006 | 07:45 PM
Chrissy_bwoy
its electrical then
possibly a dodger sender, i swapped from an electrical to a mechanical cos the sender was unreliable.
Ian1964
12
Jan 26, 2021 11:57 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
dombanks
Sep 21, 2015 08:38 PM
Adam Graham
Sep 6, 2015 06:04 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
