Uprated 2L zetec focus engine ready for a turbo only £850!
Added Images...
Brand new 803 green injectors and 3-bar map sensor.
Brand new T3 cosworth stage 1 hybrid turbo.
More pictures of the other parts i have are on there way soon.
I am selling my 2.0L uprated Zetec engine which I have been planning to put in my focus for quite some time now. As you probably guessed this is a very reluctant sale, but do to moving out I have had decided to abandon the project.
I bought a focus 2.0 zetec engine and had it overbored and added focus central 8.2.1 forged Pistons (oversized) and added Eagle connecting steel conrods, (which certainly don't come cheap) Multi layer steel focus head gasket. Also oil eed and return has been put in. So this lump can handle a lot of stress. The engine itself is fully built (to avoid confusion this is a 2.0 zetec engine not a duratec as in one of the pictures its has a duratec cover but it comes with a black zetec one).
I also have a Brand New turbo technics T3 4x4 Turbo (cost over £580) , Ford cosworth 4x4 intercooler, RS turbo exhaust manifold with zetec adaptor plate, and Bosch 803 dark green injectors plus a 3-bar map sensor (Magneti Marelli). (All not attached)
This engine has cost me a fair wack is certainly capable of some serious power (my target was 300bhp) and with only a few more parts it can easily be completed. Most performance garages could easily finish the project for you as a lot of the work as already been done.
Engine Spec:
• 2.0 Zetec Turbo 16v (Series 3 engine)
• 85mm bore/88mm stroke
• Eagle Forged Steel H Section Conrods
• Focus Central 8.2:1 Forged Pistons
• ARP Rod Bolts
• Piston oil spray jets
• Standard Focus Head
• Ford 130ps Cams
• Multi Layer Steel Focus Head gasket
• Ford Cosworth 4x4 Intercooler
• RS Turbo Exhaust Manifold with Zetec Adapter Plate
• Brand New Turbo Technics T3 4x4 Turbo
• Bosch 803 Dark Green Injectors
• 3 Bar M.A.P Sensor
As you can see I have spent a fair wack on this zetec turbo conversion , so if you looking to add some serious power to your motor give me a call! If
The engine itself £850
Brand new t3 stage 1 hybrid turbo - £350
Brand new 803 Dark Green Injectors: £150
Cosworth 4x4 intercooler £45
3-Bar Map sensor £60
Rs turbo exhaust manifold with zetec adaptor plate. £80
This cost me alot more than I am selling it for, so somebody is going to get a bargin.
Any questions please call me on 07768201837 or 01594531161
Thanks for reading.
Josh Harris
JoeyBoyden
Jan 4, 2024 02:36 PM
