cos problems
Old Sep 19, 2006 | 08:02 PM
Giwrgos_77's Avatar
Giwrgos_77
Default cos problems
I have a sierra 4x4 cat with 3 bar map sensor-chip actuator-fuel pump etc...when it tries to past 1 bar and 5.000 rpm it makes like it hits the rev limit! We also can not make a custom chip to the rolling road due to this problem, i have been told that it sould be the map sensor...if anyone had similar experience please share it with me. Thanks
Old Sep 21, 2006 | 10:56 AM
Mr 19"'s Avatar
Mr 19"
Have you fettled with the cables behind the distributor? If so, you may have put them on the wrong way.
Old Sep 21, 2006 | 04:39 PM
Giwrgos_77's Avatar
Giwrgos_77
Thank you for your response, the cables are fine i believe it is the map sensor....
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
`spotty
Sep 25, 2015 11:41 PM
Russ Payne
Sep 25, 2015 08:29 PM
