safe & reliable bhp
Old Sep 19, 2006 | 08:01 PM
Maxxeh's Avatar
Maxxeh
Default safe & reliable bhp
whats a reliable bhp you can run on a 1600 cvh engine?
Old Sep 19, 2006 | 09:12 PM
Rick's Avatar
Rick
depends on the engine spec. Std internals you can argue anywhere betweem 180 and 250 bhp.
Old Sep 19, 2006 | 10:09 PM
DazC's Avatar
DazC
Easiest way is to decide what power output you want and then build the engine to suit that output.
If you are talking a completely standard engine apart from head work, probably 240 would be the safe and sensible limit.
Old Sep 20, 2006 | 05:23 PM
ivorbiggun's Avatar
ivorbiggun
180 after which clutches and gearboxes let go with alarming regularity. The up side is you'll get quick a changing them.
Old Sep 20, 2006 | 05:34 PM
XR2's Avatar
XR2
And how you abuse them
Old Sep 20, 2006 | 06:20 PM
notSteveS2's Avatar
notSteveS2
id say 132bhp.....
after that they r constant agro... everythin goes wrong...
Old Sep 21, 2006 | 04:10 AM
Diamonds.'s Avatar
Diamonds.
Originally Posted by notSteveS2
id say 132bhp.....
but true
Old Sep 21, 2006 | 05:10 AM
Moonie's Avatar
Moonie
id say 132bhp.....
Beat me to it
How reliable the engine is will also depend on how much mechanical sympathy the driver has.
Old Sep 21, 2006 | 09:48 AM
scotty86d's Avatar
scotty86d
Making sure its serviced with good quality parts and set up regularly too.
Old Sep 21, 2006 | 06:46 PM
MJC's Avatar
MJC
I really don't know why people have digs at rs turbo's and ford cvh engines.... Mine runs a very reliable 200bhp and have only had the fuel pump relay go during my time of ownership. Been by far the most reliable car I have ever owned as long as it is a healthy engine and is serviced at the correct intervals you will be fine. I recon 200bhp on a pritty much standard engine is your best bet as you do start pushing the limits of the standard components such as conrods etc.
Old Sep 22, 2006 | 12:41 PM
Escort.Cosworth's Avatar
Escort.Cosworth
I was looking into getting the boost turnt up on mine but wasnt sure what sort of psi it would handle till it goes BANG
Engine's standard but do have chipped ecu
Would it run a safe 15psi?
Old Sep 22, 2006 | 02:36 PM
Micky's Avatar
Micky
I couldnt agree more.I've used my engine with std internals/headgasket/head,running between 16-18 psi for trackdays since 1995 and its still running very strong (ask Tim and Ollie!! ).Keep it regularly services and all will be well.Regards,Micky
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Marv888
Sep 26, 2015 03:44 PM
