not quite pre 1980, but still... capri question
24v Cosworth V6 into a 2 litre laser?
what needs doing? which mounts to use etc?
does the crossmember need changing?
i know nothing about capris, but i've done engine swaps on sierras before.
any help muchly appreciated
Its a bloody pain in the ass!
Well, stripping the Granada is
You'll need:
V6 Crossmember (And power steering rack)
Gearbox - Type 9 from 2.8i, or MT75 (Contact caprisport)
Mounting brackets, and rubbers for 2.8i capri engine
clutch kit, and spigot bearing for manual gearbox
Flywheel and propshaft from 2.8i
Wiring and engine/exhaust manis from granada
Radiator from larger car (The capri one, and viscous fan is wang)
A lot of patience.
Im about 2/3 the way through fitting this to my 2.0S, and you need to take the stance of 'work out how much you think it will cost, then add 50% on again for sundries', because you find loads of things you've forgotten about!
Best of luck!
ToGGoT
You'll need:
A lot of patience.
Best of luck!
ToGGoT
