mk 3 door locks
Old Sep 19, 2006 | 02:00 PM
chelseabully1's Avatar
chelseabully1
Default mk 3 door locks
hello i wonder if any of you guys can help me with my s1
just quick really
car opens when i press alarm but dont close when i press it again just goes though the motions ie the pin goes down but not enough
any help would be great
cheers justin
Old Sep 19, 2006 | 04:22 PM
SafeChav's Avatar
SafeChav
Do you mean the drivers door pin goes down but not enough?
Old Sep 19, 2006 | 08:06 PM
MarkN's Avatar
MarkN
Mk3 Escorts have always been prone to this, particularly on the back doors for some reason, but you don't need to worry about those
It's unlikely that your car has the original system still fitted as mk3 escorts didn't have a solenoid in the drivers door - just a switch. This meant that if you fitted remote locking the drivers door wouldn't work.
Someone has probably got around this by fitting motors from a Mk4 Escort, and this is probably out of adjustment as they take a bit of fiddling with. Take off the door panel and have a look at the rod that connects the motor to the latch, it probably needs shortening slightly and bending it slightly might be sufficient.
Old Sep 19, 2006 | 08:24 PM
SafeChav's Avatar
SafeChav
Your havin a laugh aren't ya? Thats mega work! I bet its just got a solenoid fitted in drivers door to operate the switch, and they are a slag to fit and get working properly!
Old Sep 19, 2006 | 09:02 PM
MarkN's Avatar
MarkN
lol no I've done it loads of times, - I've always found the motors work so much better than the solenoids. Although I must admit they take a lot of fiddling with to get right.
My 85 cabriolet even had the screw holes for the motors in the doors, although not the ones for the electric window motors unfortunately...
Old Sep 20, 2006 | 09:38 AM
SafeChav's Avatar
SafeChav
MarkN your mad thats mega work, especially seeing as you have to discard the relay from under the glove compartment and re-wire it all!
If you look into it its actually easier to fit a proper MK3 solenoid onto the lock in the drivers door.
And just for the record, the reason they go stiff is lack of maintenaince, my 85 Orion has never had the door cards off and every lock works perfectly. Solenoids are a lot stronger than the motor driven items today.
You were lucky with your cabby, mine is one of the very first 84 models, no holes for anything! But i still fitted a full set of electric windows, mirrors and central locking!
stephenb4506
33
Oct 2, 2015 06:25 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
mpilk
Sep 27, 2015 09:21 AM
