Turbo and ECU compatability
Old Sep 18, 2006 | 11:08 PM
AdamS2's Avatar
AdamS2
Default Turbo and ECU compatability
Hi all, turbo died on my series2 a while ago (oil seals).
Got a replacement in post today. It has no water ports, inlet or outlet.
So far I have found out that this is from a series 1 as it is oil cooled.
Can it be fitted to my S2 and driven reliably by blocking off water supply hoses??
I also have a chipped ECU but it is again from a series 1 (blue/red/blue) compared to mine s2 (hearts/diamonds)
although this unit does not support the knock sensor can it be used?
Thanks for your time
Old Sep 18, 2006 | 11:15 PM
gambit's Avatar
gambit
Default ecu
I use a series one ecu on my series2 without problems, you are correct in saying the knock sensor will no longer be in use. Alot of tuners say that the series one ecu is there prefered ecu, but i dont know why. As for the turbo as far as i am aware alot of people run them without being water cooled inorder to reduce the overall engine temps however i dont know how reliable or safe that is but i am sure you will have more replys soon.
Old Sep 19, 2006 | 10:37 AM
SafeChav's Avatar
SafeChav
The turbo will be fine as long as you connect the 2 pipe ends together (IMO this is better than blocking them)
And the ECU again will be fine, the series 1 ECU as said does not have an input for the knock sensor, which is said to be a good thing as the noisy top ends on CVH's can fool the ECU into thinking there is knock, so it will adjust the ignition timing accordingly.
Remember to get it set up though as the chip is from another car
Old Sep 19, 2006 | 06:02 PM
sime73's Avatar
sime73
im running a s1 turbo on mine without probs
Old Sep 19, 2006 | 07:44 PM
AdamS2's Avatar
AdamS2
Thanks.
Old Sep 21, 2006 | 10:26 AM
ivorbiggun's Avatar
ivorbiggun
Send it back and get the correct bit for the job
Why on earth dyo think Ford bothered to water cool the later one?
Old Sep 21, 2006 | 10:28 AM
ivorbiggun's Avatar
ivorbiggun
P.S.
The S1 ecu is more than up to the job
Old Sep 21, 2006 | 10:29 PM
Rick's Avatar
Rick
You will have no problem. The water cooling was added in an attempt to stop the carbon deposits appearing on the shaft due to people working the turbo and then turning off the engine and oil supply. Drive gently for a mile or so before u turn off and it will be fine.
Old Sep 22, 2006 | 06:34 PM
AdamS2's Avatar
AdamS2
Cheers, been wanting to put a turbo timer on old RST for a long time. This, I think will be a good incentive.
I have a HKS TT on my Nissan but I would imagine one of these is not compatable with the RS. Anybody recommend any??
Old Sep 22, 2006 | 06:39 PM
Rick's Avatar
Rick
Any TT will work mate - i run a Blitz.
Old Sep 22, 2006 | 10:44 PM
Zetecfiesta's Avatar
Zetecfiesta
i really need a turbo timer gonna get my mate to run a relay in my alarm system though, cheaper than buying a turbo timer!
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
Marcus L
Aug 29, 2015 02:18 PM
IAN RS2k
Aug 18, 2015 07:51 PM
