When replacing valve stem oil seals
Old Sep 18, 2006 | 06:15 PM
davidnormanuk's Avatar
davidnormanuk
Default When replacing valve stem oil seals
dont forget to block the oil return holes that go to sump incase any of the valve collets fall into them. Did this on mine now I've got to drop the sump off to get them out.
Old Sep 18, 2006 | 06:45 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
get a extendable magnet and run it down the hole you lost the collet down, get a small 1 and it'll fit a treat
fook takin the sump off too i'd leave it in there, aint gonna come to any harm sat in the bottom
newuns are 30 p from ford i think
Old Sep 18, 2006 | 06:49 PM
davidnormanuk
I've got some spare but after completely replacing the bottom end I'd rather not risk running it. Just for piece of mind. Had a mate who dropped a washer in his Vectra's sump 2 years later it got sucked through the oil pickup and knacked his oil pump up.
Old Sep 18, 2006 | 06:52 PM
1.9 xr2 on 40's
st170 breaking
it aint gonna get sucked thru the mesh on the pick up tho mate
worst case i can see is it getting flicked up between the crank and summet but the likerlyhood of it jumping up out of a tub full of oil (when its gonna sit at the bottom) is pretty unlikerly, whatever makes you happy tho mate, try the magnet 1st done it before and works a treat, for £2 off the market i'd give it a bash 1st
Old Sep 18, 2006 | 06:53 PM
Rick's Avatar
Rick
leave em there, they wont do any harm. Know loads of people who have done this. The pick up strainer wont allow them into the pump.
Old Sep 18, 2006 | 06:55 PM
xrchris's Avatar
xrchris
or just drain the oil out, must be cheaper to do that than buy a new sump gasket
chris
Old Sep 18, 2006 | 06:57 PM
davidnormanuk
I'm gonna get a magnet tomorrow and take it from there. Thanks for the input. Nice to know I'm not the only one.
Old Sep 18, 2006 | 07:08 PM
nigel b's Avatar
nigel b
drain the oil and use a small magnet in the drain hole
you should be able to find it easy enough
Old Sep 19, 2006 | 08:15 AM
addiction's Avatar
addiction
YODI
Aug 30, 2015 01:12 PM
Danielbetty
Aug 28, 2015 08:01 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
st220kyle
16
Aug 14, 2015 06:13 AM
