XR3i Inlet Manifold onto MFI
Old Sep 18, 2006 | 05:46 PM
dave_y's Avatar
dave_y
Default XR3i Inlet Manifold onto MFI
ok i have done a search and didn't find a definitive answer.
How much of a mission is it gonna be to fit an XR3i manifold (like what Christian has on his RST) to an MFI RS Turbo?
By looking at it, the problems are going to be in the form of fitting the cold start injector and knock sensor etc?
Can anyone shed any light on this?
Old Sep 18, 2006 | 07:54 PM
XR2's Avatar
XR2
Cold start injector is just the same.
XR3i MFI was available with KE-Jetronic and TPS and knock sensor in Germany so you'll get all parts you need for the XR3i inlet. Just the throttle is bigger!
Old Sep 18, 2006 | 08:29 PM
dave_y's Avatar
dave_y
ok, i shall go and strip the xr tomorrow
Old Sep 18, 2006 | 08:30 PM
dave_y's Avatar
dave_y
is there anything else i should take off it such as the fuel lines etc as the CSV cant be in exactly the same place surely?
Old Sep 18, 2006 | 08:31 PM
xrchris's Avatar
xrchris
a good guide is www.rsbible.co.uk
Old Sep 18, 2006 | 08:33 PM
dave_y's Avatar
dave_y
im staying MFI for the time being....
Old Sep 18, 2006 | 08:41 PM
XR2's Avatar
XR2
You'll have to modify the fuel line for the csv.
And you can't use all of the UK XR3i parts. These cars didn't come with knock sensor and TPS!
Old Sep 18, 2006 | 08:53 PM
se mk3 cabbie's Avatar
se mk3 cabbie
sorry to butt in mate, how hard is it to put said inlet on efi
Old Sep 18, 2006 | 09:00 PM
dave_y's Avatar
dave_y
does anybopdy have a picture of one.....
i noticed that they have a union on the front left of the manifold which is used for a breather. can i bung the knock sensor in there as i would only be blocking off the breather port anyway....
Old Sep 18, 2006 | 09:15 PM
XR2's Avatar
XR2
This car has got KE-Jet:
http://fordescort.britec-online.de/s...php?show_id=59
Don't know exactly where the knock sensor sits on this engine, iirr it's screwed directly onto the bottom end. If you use your turbo one, be sure it will sit on the right place or it won't fit. So you can't use the breather screw.
Conversion to EFI can also be done. Throttle housing can be used, modifications for the fuel injectors are the same if you want to convert your ERST manifold to EFI
Old Sep 18, 2006 | 09:27 PM
dave_y's Avatar
dave_y
ok well i will go and get one to have a play with if nothing else.....
Old Sep 18, 2006 | 09:42 PM
SafeChav's Avatar
SafeChav
Spot the deliberate and IMO VERY SERIOUS fault with the engine in those pictures
Old Sep 18, 2006 | 09:45 PM
XR2's Avatar
XR2
That would be? No cambelt cover and a RSi rocker cover on a XR3i engine with 90 hp???
Old Sep 18, 2006 | 09:53 PM
SafeChav's Avatar
SafeChav
Try looking a little harder at the cam belt
Old Sep 18, 2006 | 09:57 PM
XR2's Avatar
XR2
Should get a new one?
Holger built a totally new engine, so this won't be a problem now
Old Sep 18, 2006 | 10:00 PM
SafeChav's Avatar
SafeChav
Looks like stevie wonder fitted the cam belt, thats totally wrong
Probably best its got a new engine!
Nov 1, 2015 06:53 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Fudgey
21
Sep 30, 2015 06:19 PM
caprixpack
Sep 25, 2015 07:53 PM
