Clutch
hi ppl
My clutch went the other day on my Escort, so Im going to attempt to change it myself. Im fairly good with my hands and have a faitr bit experience with engines so im not jumping in at the deep end. Im just wondering if anyone has any quick guides/tips to make my job a bit easier, as ive never done a clutch before on an escort? IE what has to come out? metering head looks like the first!
thanks in advance
Jamie
thanks in advance
Jamie
metering head stays in place as the box come out from the bottom.
anti roll bar off
starter motor off
abs belts/modulators off
clutch/speedo cable off
driveshafts out
support engine with some form of jack or from the top
then undo the gearbox cradle
lower engine/box together then slide gearbox off
there are probably bits ive missed.
i swapped a gearbox on my tubo a few months ago and i have never done any work on a car before really (apart from oil change etc)
what i will say is get a Haynes guide as thats what i used and its pretty straightforward.
out with the old
in with the new
if you have any problem while doing it then you can send me a pm if you like and i will talk you through it in more detail
anti roll bar off
starter motor off
driveshafts out
out with the old
in with the new
not so hard getting it out cept for the lower control arms , a lot easier with the anti roll bar disconected from the front
also found it a piece off piss to put back with a chain hoist above the box and used a long piece of rope to make a type of cradle to the hook on the hoist. you can the get the height to line it up and swivel it to get the angle spot on with this - one man job like this
i also use a piece of carpet or the like to stop the crank pulley mucking your paint up when you drop the motor
thanks for the replies folks, got my clutch thismorning will start it shortly. Not sure about the ABS, but ive just stripped an Orion RST that I ha and was wondering what the belts aroun the riveshafts were! that explains it.
cheers again, im sure ill be in touch!
Jamie
Jamie
well its been 2 full days, but my clutch is done! what a bloody shift. all went well ill it was time to put the gearbox back in! lining it up an keeping all cables out the way at the same time, and i dont it myself without a hoist etc! never again. coulnt get the ABS belts on but ill do that at the weekend.
cheers
cheers
Thats the one bit that everyone will agree with you is the hardest bit, getting the input shaft aligned with the clutch plate
Theres not a lot of need for a hoist, i think most do it without
Well done
Well done
Which is where my hydralic transmission jack comes in handy makes job
lining up the proverbial p of p!
Anyone in North east Londons welcome to borrow it for Refundable deposit
of £50 and price of couple of stella's/'whats that you say Bitch?' Slap etc.
Adjustable engine bar from your local Snap on man (on special at £30 at the mo) is a cracking bit of kit as well that as it's adjustable up and down as well as width ways makes it easier as well.
If fact (business opertunity alert) any of you are welcome to borrow 3 tonne hoist,2 tonne tranny jack and engine bar for £250 deposit and 2 cases of
Belgians Brew.....
Belgians Brew.....
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
