brakes continued from yesterday.
Right instead of cossie calipers what about brembos. Looking on e bay you can get 406 coupe or fiat coupe brembos reasonable. on the right cars they come with a 300mm disc, so...
how easy are these calipers to be made to fit? does anybody make brackets for them?
could I then use a 300mm disc from like an st170?
cheers
cheers
i dont know what lenght bolts u have in there to connect the custum bracket but u need slightly longer ones... minimum flush with the nut but technically 3 threads sticking through.
just an observation.
that is exactely what I want. where did you get the brackets mate?
does anybody know if the fiat coupe and 406 coupe brembos are the same as these seem to be cheaper. they look the same as the focus rs ones
cheers
cheers
FIAT and 406 calipers are mounted differently.FOCUS RS are mounted from the sides and FIAT & 406 are mounted from the top.My brackets were Ł80.Take your HUB & CALIPER to a MACHINE SHOP and they should be able to make you some brackets.Ask on here if there is anyone that specializes in your choice of brake conversion.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
