My new ride.
Originally Posted by costina
Is that the one running megasqurt ? i'm sure i've spoke to the guy how was building it
Looks good
Looks good
Here's some plans about the setup it will be running next year..
- 2wd cosw block with std crank / con-rods and wiseco pistons.
- Ported pinto head,big inlet valves,camshaft ??.
- Large ic.
- Turbo??(Holset hx35w,garret t3/4???We'll see.)
- Megasquirt.
- etc....
sounds good why not just drop a YB in there
Originally Posted by bortaf
Looks nice
love the wheels mate, don't think i've ever seen such a huge offset on a corty
I ran 9x16 escos wheels on mine looked wide but the sus is too low for um,now running 8x18's
Shame about the power limitation what will they let you go up too?and do you have to pay loads of Tax if you go past that???
Still a cool car thou
Hello Finlanders, I have been to Finland three times for the 1000 lakes rally, I couldn't believe the huge retro Ford folowing over there US and UK. Mustang, Capri, Granada,Cortina and Escort. You have the bonus that you use studded tyres and not salt as over here.
It's quite hard to explain the rules we've got here cause they're not allways so easy to understand.
Is it linked to emissions then?sounds very complicated
good luck with your project nice to see a mark 4 for a change
If you update the brakes on your car to bigger/stronger or change the engine/gearbox they'll count the precentage of how much you've changed the car. Up to 49,9% is it allowed without paying the taxes again. When the percentage is more than 50% you have to pay the taxes.
Mk4, the forgoten cortina
seems like they are on the up at last though
a few more real nice ones like yours will help no end i recon
do they sell well over there?
Mk3's (TC1? over there?) are well sort after here but the taunus Mk2 just doesn't seem to be loved, Mk5 get a fair bit of attention on the tuining front, not a lot but still more than the Mk4/Taunus Mk2.
Theres a lime green 2-door MK4 Cortina/MK2 Taunus in Jyvaskyla I'll post a pic of it if I can find it.
http://www.cosworthrsclub.com/klassi...assikko38.html
Are you near there?
I've ordered some parts again,big IC,radiator breather tank and an oil catch can.
Originally Posted by jesus48[fin
Nope,he never managed to get it work properly. I think he had some problems with the ignition.
- Large ic.
- Megasquirt.
- etc....
Looks good
Looks good
- Large ic.
- Megasquirt.
- etc....
- Turbo Holset H1E/HX35,52/54.
- Wastegate HKS type 50mm.
Today I was a couple of hours in our garage and here's some pics of what I've done.
Broken..
Broken..
What a mess..
And here's a few pics of the garage.. -> http://smg.photobucket.com/albums/v336/jesus48/talli/
Broken..
Broken..
What a mess..
Looking good, what intake manifold are going to use????
Pinto injection???
Pinto injection???
