Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
no longer reqd
Old Sep 16, 2006 | 09:26 PM
THE RADMAN's Avatar
THE RADMAN
Default no longer reqd
anyone got any hubcentric wheel spacers for my monte,need to be 17/18/19 mm wide
Old Sep 16, 2006 | 09:43 PM
jon@work's Avatar
jon@work
Yeah - I had some made up years ago but never used them. I'll hunt them out and get some pics tomorrow. IIRC they're 19mm.
Old Sep 16, 2006 | 09:44 PM
novarally's Avatar
novarally
I've got a set of brand new alloy spacers which might be suitable for you.
Drop me an e-mail at :
colinesmith@aol.com
and I can tell you more, and get you some photos and measurements.
Colin
Old Sep 17, 2006 | 09:18 AM
THE RADMAN's Avatar
THE RADMAN
cheers folks,will await pics /details
Old Sep 17, 2006 | 04:46 PM
jon@work's Avatar
jon@work
I had these made up for a cossie capri a few years ago (which they fitted fine) BUT I've just tried them on both a 3dr hub and a 2wd sapph hub and they don't fit. The central 63.5mm hub is either 19.5mm deep (sapph) or 21mm deep (3dr). The spacers I've got have got a 19mm deep recess. Measure up your Escort hub centre depth - they may be OK for 4x4 hubs, but I haven't got any to try the spacers out on. If your hub centre is deeper than 19mm, then you won't find any spacers that will fit unless you get a few mm machined from your hubs, in which case these will fit fine.
DavidK
Sep 27, 2015 02:55 PM
TC-ST3
Sep 26, 2015 04:47 PM
Ridgey
Sep 13, 2015 08:43 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
