mechanical or electric gauges
Old Sep 14, 2006 | 09:20 PM
Maxxeh's Avatar
Maxxeh
Default mechanical or electric gauges
Which ones should i go for?
Old Sep 14, 2006 | 09:35 PM
Rick's Avatar
Rick
depends mate. on make and what u want to measure.
Old Sep 14, 2006 | 10:01 PM
Maxxeh's Avatar
Maxxeh
oil pressure, oil temp and water temp
Old Sep 14, 2006 | 10:16 PM
dave_y's Avatar
dave_y
i would go for electrical gauges on the basis that i wouldnt want oil/water lines running in to the car.
the only mechanical gauge i would go for is a boost gauge
Old Sep 14, 2006 | 10:17 PM
Rick's Avatar
Rick
unless u spending big money on stepper motor stuff, then mechanical, elec, elec.
Old Sep 16, 2006 | 07:19 AM
steven botes's Avatar
steven botes
electrical if possible , i had a oil pressure line come loose behind the guage and had 4 bar worth of oil all over my footwell , and since i had removed the carpets , it was a bastard to clean.
Old Sep 16, 2006 | 04:28 PM
SafeChav's Avatar
SafeChav
I too have had an oil pipe burst off inside the car, luckily i spotted it instantly and there was little mess.
Electric all the way now!
Old Sep 16, 2006 | 06:59 PM
Rick's Avatar
Rick
electric pressure gauges are usually naff
Old Sep 16, 2006 | 07:06 PM
SafeChav's Avatar
SafeChav
Oh sorry did you say something
Old Sep 16, 2006 | 07:18 PM
scottbrown's Avatar
scottbrown
so where do the electric gauges get there reading from then?
Old Sep 16, 2006 | 07:19 PM
SafeChav's Avatar
SafeChav
Same place, not as accurate or responsive as a mechanical one though i would imagine.
Old Sep 16, 2006 | 07:22 PM
scottbrown's Avatar
scottbrown
if using mechanical you run a pipe ie, boost off of vacum hose, so how do the electric gauges get there reading? or am I being thick and the reading is taken as above just displayed in digital
Old Sep 16, 2006 | 07:23 PM
SafeChav's Avatar
SafeChav
Ah, i was talking about oil pressure. Mechanical boost gauges are all good
Old Sep 17, 2006 | 06:13 AM
steven botes
readings are taken from a sender unit which screws into the source
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
stevecfrst1
Sep 30, 2015 05:18 AM
20/20 vision
Sep 29, 2015 11:27 AM
