oily film in header tank?
Old Sep 14, 2006 | 08:55 PM
392B.H.P.SAFF's Avatar
392B.H.P.SAFF
Default oily film in header tank?
have noticed tonight that there is a slight oily film sitting on top of the water in my header tank
at first i thought head gasket but checked dip stick and filler cap and no cream
also when giving it larry large the temp shoots straight up,but have noticed that there is coolant all being sprayed out from the cap?is my cap fooked its a pace alloy header tank with a standard yellow ford pressure cap/
help
Old Sep 14, 2006 | 09:05 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Cracked block ?
Thats what mine was
I hope not.
Steve.
Old Sep 14, 2006 | 09:07 PM
392B.H.P.SAFF
me 2
Old Sep 14, 2006 | 09:25 PM
simonc's Avatar
simonc
mine sprays out from the cap on the header tank but only on trackdays.
Simon.
Old Sep 14, 2006 | 09:27 PM
paul16v's Avatar
paul16v
Monte 087
Me mates monte started doing that a few days before the engine blew up in spectacular fashon
Old Sep 14, 2006 | 09:32 PM
tregmatt's Avatar
tregmatt
mine use to do it before ihad it rebuilt it was the head gaskit all because
my fans wasent working
Old Sep 14, 2006 | 09:33 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I'm sorry, but don't sound good.
Old Sep 14, 2006 | 09:43 PM
Noisy Boy's Avatar
Noisy Boy
Well, You do push it mate! i mean racing evos and anything in sight got to take its toll some where!
Old Sep 15, 2006 | 08:53 AM
Cawood's Avatar
Cawood
shit mine got sludgey stuff in the header tank as well!
Old Sep 15, 2006 | 08:55 AM
Adrenaline Junkie's Avatar
Adrenaline Junkie
Thats not good
Old Sep 15, 2006 | 09:05 AM
biglee's Avatar
biglee
Audio specialist
best thing to do is go and get a leakdown test done on the cylinders, this will tell you if your head gasket is suspect....or you have a crack in the combustion chambre (head not block) it will show up as a leak...funnily enuf
if all is well with the leakdown then im afraid you have bigger problems....ie crack in ya block...
Old Sep 15, 2006 | 09:09 AM
Guinnless's Avatar
Guinnless
It may just be the head gasket.
Old Sep 15, 2006 | 09:39 AM
Andreas's Avatar
Andreas
Most likely head gasket, seen this on several cars.
Old Sep 15, 2006 | 03:21 PM
Guinnless's Avatar
Guinnless
Yeah, but we shouldn't stop the doom mongers fun
Old Sep 15, 2006 | 03:26 PM
Dan Cossie's Avatar
Dan Cossie
Doomed Doomed i tell ya lol
Old Sep 15, 2006 | 03:49 PM
graham c's Avatar
graham c
do comp test that will tell you but its gasket or block hope 4 the gasket
Old Sep 15, 2006 | 03:56 PM
Cawood's Avatar
Cawood
what sort of place can do this?
can i go to any old garage or does it have to be a speciallist tuners?
Old Sep 15, 2006 | 04:00 PM
slowpoke's Avatar
slowpoke
mines doing this at the moment too lol
no sludge on dipstick etc, engine temps fine, no smokey zorst either
the cars running fine other than this oily film
matt
Old Sep 15, 2006 | 04:01 PM
Dicko&Vacant's Avatar
Dicko&Vacant
what you mean it isnt a driveway ornament? my god theres another person on this forum who drives their car like they should
Old Sep 15, 2006 | 04:08 PM
Dan Cossie's Avatar
Dan Cossie
9awaits backlash from ornament drivers hahahahhahahah
Old Sep 15, 2006 | 05:34 PM
392B.H.P.SAFF
it can idle all day long and the temp wont go above halfway,there's no smoke from the exhaust,ans as said no sludge on dipstick or filler cap,just as soon as i give it 30psi it just shoots straight up but the only reason i can see this is because half of the coolant is being sprayed over the engine bay
booked in for a a test on sunday
fingers crossed
bloody car got a list of new parts to go on it as well,for even more power
Old Sep 15, 2006 | 06:30 PM
graham c's Avatar
graham c
you need a micanic friend if poss
Old Sep 16, 2006 | 11:04 PM
Noisy Boy's Avatar
Noisy Boy
I mean if you seen this guys car go you know what i mean, bloody thing scared the shit out of me!!
Old Sep 17, 2006 | 02:04 AM
biglee's Avatar
biglee
Audio specialist
fingers crossed
head gasket fooked cylinder to water jacket... not enuf of a bang on idle to cause any pressurising of the water system, however on 30psi i would imagen its pushing past the break like mad.... good luck....and a comp test might not show it up if your car is ok on idle, what you really need is a 150psi air line and do a LEAKDOWN test..... this will tell you much more,,,
Old Sep 17, 2006 | 02:38 AM
keo_rsturbo's Avatar
keo_rsturbo
i drove for a week after spotting this then the head gasket went with the block and at the time my oil cap was normal.
Old Sep 17, 2006 | 08:29 AM
The Youth.'s Avatar
The Youth.
Driving it "like it should" has probable fooked it!!!!
Revs kill engines fact
on turbocharged cars revs and or too much boost kill engines fact
so lay off the rev limiters and watch ya boost pressures
At the ring last week I set myself a rev limit of 5k still got round in similar times to more powerfull cars
still broke the car tho so what do I know!!!!!
Old Sep 17, 2006 | 09:51 AM
Dicko&Vacant
for some cars id agree, others id say it depends whats been done..... you know how the cossie gets driven, and how much boost it runs.....
im yet to blow it up after 2.5 yrs
Old Sep 17, 2006 | 03:32 PM
Malc50's Avatar
Malc50
My car did this and it was the begining of the head gasket going. new gasket and all was fine
I hope this helps
Malc
Old Sep 18, 2006 | 09:02 AM
Cawood's Avatar
Cawood
mines the same no sludge on dipstick or oil cap, doesn't smoke or effect its drive. temps are fine as well
just uses coolant up & has a oil film on top, (and is discoloured, like oil is in the header tank)
does that just sound like head gasket or something more serious?
also whats sort of garage can i get a comp test done at?
Old Sep 18, 2006 | 09:20 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
fingers crossed
that happens when the head bolts/studs cant keep the head on the block ,and thay sepererate, allowing the head gasket to leak on boost.
is it long studded? if so i would check who made the studs.
Nov 1, 2015 06:53 PM
mpilk
Sep 27, 2015 09:21 AM
IainRS1700T
Sep 25, 2015 06:44 AM
